March 14, 201313 yr #11 Same here no topics in "all topics" or "unread" tapatalk 1 latest version only started 2 weeks ago, very annoyingAlso its only on this forum too, have a couple other ones I go on and they are fine Edited March 14, 201313 yr by bionicxr6t05
March 14, 201313 yr #17 Hi guys,The problem with View New Content is being caused by the Tapatalk plugin. I can only assume it's because we have an outdated version as this the only forum I have problems with Tapatalk on.You'll find that after trying to use View New Content via Tapatalk that it doesn't work on a computer either. This is occurring because a third search option is being activated by the Tapatalk plugin when you try and view new posts.To get View New Content working again on your computer select View New Content and click on the filter option I've highlighted with a red circle below to deselect it...View New Content will now work properly. Using Tapatalk to find new posts will cause the issue to happen again, so don't use that.I know this doesn't solve the problem, but at least you'll get View New Content working again on your computer.
March 14, 201313 yr #20 Actually the fix for pc also works on safari for ios, so can view new content using safari!
