Tom Oldfield Member 11 Member For: 14y 8m 4d Posted 02/03/13 09:01 AM Posted 02/03/13 09:01 AM Have an autometer oil pressure gauge all wired up but can't get it to read anything. I've tested all the wiring with a test light. The ignition source (spliced off cigarette lighter) is strong and the ground seems to be strong (screwed to a sanded area of the aluminium framing behind the dash). The sender wire is very dim on the test light but I assumed this was because there is not much pressure as the car idles. However, when I rev it I though the signal would increase but it doesn't. Can anyone suggest where I'm going wrong?
JETURBO ...JD TUNING ADELAIDE... Legacy Donating Member 23,708 Member For: 18y 3m 27d Gender: Male Location: Adelaide Posted 02/03/13 09:09 AM Posted 02/03/13 09:09 AM What did u use to seal the thread on the sender ?
Tom Oldfield Member 11 Member For: 14y 8m 4d Posted 02/03/13 09:21 AM Author Posted 02/03/13 09:21 AM What did u use to seal the thread on the sender ?teflon tape
ratter Member 6,793 Member For: 20y 3m 30d Gender: Male Location: @ my laptop Posted 02/03/13 09:23 AM Posted 02/03/13 09:23 AM you haven't covered the opening?
Tom Oldfield Member 11 Member For: 14y 8m 4d Posted 02/03/13 09:30 AM Author Posted 02/03/13 09:30 AM you haven't covered the opening?I guess its possible but I doubt it I didn't use a lot of teflon. Might have to check
Macy New Member 20 Member For: 17y 24d Gender: Male Posted 02/03/13 10:55 AM Posted 02/03/13 10:55 AM sometimes the terminal tabs on back of gauges are loose from new, in my case. gauge didnt work until tightened. Try that and test outside cup holders.
freeze_dk I am dissatisfied with my current employment situation Legacy Donating Member 8,610 Member For: 19y 11m 29d Gender: Male Posted 02/03/13 10:52 PM Posted 02/03/13 10:52 PM I used the ignition wire under the dash to power mine up.. Worked for a day then stopped, so its just there looking pretty now
hotxr8 Member 49 Member For: 15y 11m 11d Gender: Male Posted 02/03/13 11:31 PM Posted 02/03/13 11:31 PM Teflon tape insulating sender from engine block.
Tom Oldfield Member 11 Member For: 14y 8m 4d Posted 03/03/13 12:06 AM Author Posted 03/03/13 12:06 AM sometimes the terminal tabs on back of gauges are loose from new, in my case. gauge didnt work until tightened. Try that and test outside cup holders.The nuts are done up pretty tight on the back of the gaugeTeflon tape insulating sender from engine block.It says to in the instructions? The oil passes through the opening in the middle....
Macy New Member 20 Member For: 17y 24d Gender: Male Posted 03/03/13 03:32 AM Posted 03/03/13 03:32 AM The nuts are done up pretty tight on the back of the gaugeIt says to in the instructions? The oil passes through the opening in the middle....r u running oil into the dash? old school. your keen ..
