EB_XR6_1992 Member 59 Member For: 12y 9m 5d Gender: Male Location: perth Posted 06/02/13 09:09 AM Share Posted 06/02/13 09:09 AM hi I just bought second hand x force twin 2.5 cat backand 100 cell 5 inch welded in cat x force as well and was curiousif I can swap the stock dump with a 4 inch x force one ???? Link to comment https://www.fordxr6turbo.com/forum/topic/83892-can-i-just-swap-the-dump-pipe/ Share on other sites More sharing options...
Kosij Donating Members 2,045 Member For: 13y 9m Gender: Male Posted 06/02/13 09:16 AM Share Posted 06/02/13 09:16 AM Yes of course you can!You will how ever overboost and Probbaly blow your engine up. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/83892-can-i-just-swap-the-dump-pipe/#findComment-1359458 Share on other sites More sharing options...
EB_XR6_1992 Member 59 Member For: 12y 9m 5d Gender: Male Location: perth Posted 06/02/13 09:19 AM Author Share Posted 06/02/13 09:19 AM so it doesn't have any problems bolting up to stock system ? Link to comment https://www.fordxr6turbo.com/forum/topic/83892-can-i-just-swap-the-dump-pipe/#findComment-1359462 Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 11m 10d Gender: Male Location: Adelaide Posted 06/02/13 09:21 AM Share Posted 06/02/13 09:21 AM nah nah nah wont bolt up to a "stock " systemxforce will work with xforcestock works with stockdont combine them Link to comment https://www.fordxr6turbo.com/forum/topic/83892-can-i-just-swap-the-dump-pipe/#findComment-1359463 Share on other sites More sharing options...
Adam Here since the start... Lifetime Members 10,282 Member For: 22y 15d Gender: Male Location: Victoria Posted 06/02/13 09:23 AM Share Posted 06/02/13 09:23 AM Xforce dump and cat will bolt up to a stock system just fine if you get the adapter pipe. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/83892-can-i-just-swap-the-dump-pipe/#findComment-1359466 Share on other sites More sharing options...
EB_XR6_1992 Member 59 Member For: 12y 9m 5d Gender: Male Location: perth Posted 06/02/13 09:29 AM Author Share Posted 06/02/13 09:29 AM yeah because I bought the middle section with a welded in cat on it and thought could I just upgrade the dump too.wasn't sure if connection point is same size as stock one so could bolt up Link to comment https://www.fordxr6turbo.com/forum/topic/83892-can-i-just-swap-the-dump-pipe/#findComment-1359473 Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 11m 10d Gender: Male Location: Adelaide Posted 06/02/13 09:31 AM Share Posted 06/02/13 09:31 AM humm if its got a welded in cat I think u may be up the garden path making that just " bolt in "sounds like u should take it all to an exhaust shop and get get them to fit it all for u as it may require a custom touch here and there Link to comment https://www.fordxr6turbo.com/forum/topic/83892-can-i-just-swap-the-dump-pipe/#findComment-1359476 Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 11m 14d Gender: Male Location: @ my laptop Posted 06/02/13 09:33 AM Share Posted 06/02/13 09:33 AM agree with Jet, 1 Link to comment https://www.fordxr6turbo.com/forum/topic/83892-can-i-just-swap-the-dump-pipe/#findComment-1359479 Share on other sites More sharing options...
timmytyme Member 23 Member For: 12y 3m 12d Posted 06/02/13 09:57 AM Share Posted 06/02/13 09:57 AM wont you need to get a larger flapper and ported? also stronger actuator? im trying to upgrade mine to a 4inch too, but this is what the tuners are suggesting. does that sound right? Link to comment https://www.fordxr6turbo.com/forum/topic/83892-can-i-just-swap-the-dump-pipe/#findComment-1359490 Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 11m 10d Gender: Male Location: Adelaide Posted 06/02/13 09:59 AM Share Posted 06/02/13 09:59 AM yes and no all depends but yeh its a great mod to do at that point Link to comment https://www.fordxr6turbo.com/forum/topic/83892-can-i-just-swap-the-dump-pipe/#findComment-1359492 Share on other sites More sharing options...
