To Oil Pump Gears Or Not To Oil Pump Gears...that Is The Question!
  • billet turbos and weathered engines dont mix
  • Member For: 13y 27d
Get it tuned for midrange torque and sh*tty tyres. Fry through gears at 3~4k and no worries!
  • I <3 Floods
  • Silver Donating Members
  • Member For: 13y 10m 17d
2wordssoftcutcheers
Looks like one big retarded word to me..
Cheers.
  • Member For: 14y 7m 27d
I just munched mine yesterday.. Missed a gear and redlined then boom no oil pressure.. Whats the average price for installing new gears including labor??
did not want to read this but I did :(
  • Member For: 17y 6m 24d
Going from memory here, but - soft cut in B series is 6000RPM, hard limiter 6200RPM.
I run Castrol Edge 0w40 oil and it takes FIFTEEN MINUTES to get to an acceptable temperature for me to give it a bootful, say 75°, then sits around 85-90° a little while after. Coolant temp is on 1/4 after FIVE mins then sits there thanks to cooler thermostat. Quite a difference in time.
If it's a really cold day make it 20 minutes to warm up and hovers closer to 80°.
This is measured via sandwich plate under oil filter and have checked against OBDII logging numbers for oil temp, gauge reads 2-4° out at 90°, again from memory.
Oil temp drops off to below gauge range of 50° after a couple of hours of car being off but comes back up quick (<5 mins). Would be colder than engine due to location of sensor.
