ridzilla Member 4 Member For: 12y 9m Posted 16/08/12 11:37 PM Share Posted 16/08/12 11:37 PM hey every,I'm Jack and I have a 2003 BA XR6 Turbo with a 2006 BF turbo motor, I was on fordforums.com but my mate Dave sent me across saying you're all much helpful!Bascially I went out this morning to go to work and when I turned to key to start my car it won't turn over, fire or really do anything. I just has one click then dead silence. But when the ignition is one and I depress the accelerator there is a rattling/loose noise coming from the throttle body near the intake.The battery has 12.42V and all leads seem tight and connected properly.Does anyone have any advice or fixes on this problem or can link me to another thread?P.S expect me around here alot, I've had nothing but trouble with this paerticular car :(Thanks again! Link to comment https://www.fordxr6turbo.com/forum/topic/81494-ba-xr6-turbo-will-not-start/ Share on other sites More sharing options...
spoken Donating Members 133 Member For: 12y 10m 13d Gender: Male Location: sydney prestons Posted 16/08/12 11:43 PM Share Posted 16/08/12 11:43 PM Link to comment https://www.fordxr6turbo.com/forum/topic/81494-ba-xr6-turbo-will-not-start/#findComment-1280458 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 7m 23d Gender: Male Location: Perth Posted 17/08/12 01:20 AM Share Posted 17/08/12 01:20 AM Batteries cactus. Put the voltmeter on it and try and crank the car. The voltage will drop to nothing. The buzzing from the TB is just the ETC trying to do its start up cycle Link to comment https://www.fordxr6turbo.com/forum/topic/81494-ba-xr6-turbo-will-not-start/#findComment-1280495 Share on other sites More sharing options...
Paulie2256 Donating Members 7,441 Member For: 16y 5m 24d Gender: Male Location: SE Melbourne Posted 17/08/12 01:22 AM Share Posted 17/08/12 01:22 AM +1 get new battery Link to comment https://www.fordxr6turbo.com/forum/topic/81494-ba-xr6-turbo-will-not-start/#findComment-1280496 Share on other sites More sharing options...
EvilDaifu Cruise Whore Moderating Team 5,130 Member For: 19y 9m 11d Gender: Male Location: Melbourne Posted 17/08/12 10:50 AM Share Posted 17/08/12 10:50 AM Yep - sounds like flat battery. Also tight connections on battery terminals mean piss all if there is heavy oxide on the inside of the connectors on the battery fly leads. Use a screw driver to scape the connectors on the fly leads and the actual battery terminals to expose bare metal. Them do em up tight. Try this before trying a new battery. Also - swap out ya battery for your mates to test if it is ya battery. Hope this helps Link to comment https://www.fordxr6turbo.com/forum/topic/81494-ba-xr6-turbo-will-not-start/#findComment-1280754 Share on other sites More sharing options...
ridzilla Member 4 Member For: 12y 9m Posted 18/08/12 08:14 AM Author Share Posted 18/08/12 08:14 AM Cheers for all the advice everyone! It ended up being a loose chassis earth, yet another thing I have to fix on this car Link to comment https://www.fordxr6turbo.com/forum/topic/81494-ba-xr6-turbo-will-not-start/#findComment-1281106 Share on other sites More sharing options...
MetalPhreak Member 28 Member For: 18y 9m 29d Posted 18/08/12 03:38 PM Share Posted 18/08/12 03:38 PM My BF Falcon had starting issues with a half dead battery, but it just made a really loud ticking/clunking noise as the starter can't turn over properly. After going through a battery every year, one morning it just would not start. All I could hear was the starter relay clicking faintly. Ended up being a cactus starter motor. Had it towed and replaced. Now it starts like new and I realised how bad its been the last 2 years... First things you check are battery voltage when cranking, ground connections, and then the starter motor. Give the starter motor a whack with something while someone tries to start it and sometimes you can get some life out of it (so you know for sure its the starter). Link to comment https://www.fordxr6turbo.com/forum/topic/81494-ba-xr6-turbo-will-not-start/#findComment-1281231 Share on other sites More sharing options...
