  • Legacy Donating Member
  • Member For: 15y 1m 29d
Posted
Could be a pats issue... Dodgy key maybe... Couldnt tell you without getttin it on ids myself... It wont be that hard to fix if you find a dealer that knows what theyre doing... Where are you located
  • Member For: 15y 4m 25d
Posted
I'm from essendon and rang essendon dealer but they are the same guys who told me back in the day my axels are bent from me lowering it....and that my alternator fuked up because I charge the iPhone without turning the car on....
I tried both keys
  • Tampon inserted, Auto Acquired, next purchase a new handbag
  • Member For: 18y 6m 5d
Posted
Sounds like what mine was doing.
Posted
Mine started to get slow to start. I dropped it at Pitlane, picked it up the next day, gave them some money, and now it's perfect.
  • 1 month later...
  • TURBOCHARGED
  • Member For: 20y 5m 8d
Posted
f*ck mines doing the same thing :(
have you fixed it yet?? what was the problem ?
  • Member For: 20y 7m 12d
Posted
*waiting someone to blame the diff bush*
These newer cars really f***n hate dying batteries.
Notice I didnt say dead.
A Battery can show good voltage with no load whilst a cell is sh*tting itself.
So, assuming your battery is newish and good with plenty of charge, then you start looking at other sh*t. Fuel, Ignition and all the good electricals involved that make that happen.
  • Member For: 15y 3m
Posted
Put the standard injectors back into it and flashed it back to standard tune. The problem is still occuring so its off to Ford to figure it out as I dont have the time to troubleshoot it.. I also think its the battery but hey!
  • Member For: 17y 11m 1d
Posted
Could be a bem plug with bent pins or not plugged in properley as im pretty sure I seen dash gauges at the cruise so the icc has been out.
