03/06/12 02:09 PM03/06/12 02:09 PM #1 Howdy fellasI want remove my xr6 badges on my side skirts and replace them with new ones what is the best way to remove them.Thanks in advance.Memo..
03/06/12 06:19 PM03/06/12 06:19 PM #2 I used fishing line, picked off the lumpy bits off glue with my finger nail then a dash of peto on a rag to remove the rest.Then washed it off of course same as you would if ya got clumsy at the servo
03/06/12 10:26 PM03/06/12 10:26 PM #3 hair dryer and credit card will do it nicely. then some prep sol and elbow grease...
04/06/12 12:08 AM04/06/12 12:08 AM #4 Haha nar use a hair dryer just a bit to make the doubl sided tape there held on by and use a razor blade and gently run it along the paint I've done a few cars this way it works well
04/06/12 09:23 AM04/06/12 09:23 AM #6 Author Excellent thanks for your help fellas I will give it a go !!
04/06/12 11:05 AM04/06/12 11:05 AM #7 I vote heat gun/hair dryer and fishing line, then eucalyptus oil to get off the glue, works excellently.Most important, patience. Don't pry them off and damage the paint.
04/06/12 11:27 AM04/06/12 11:27 AM #9 +1 hair dryer/fishing line.Although side ones are just rubber and you can peel them off with your fingernail.
10/10/12 04:42 AM10/10/12 04:42 AM #10 I used just fishing line to remove badges with prepsol and adhesive remover to clean up (from hardware store). The adhesive remover worked a little better than the prepsol. They did not affect the paint.If necessary use a hair dryer carefully to soften adhesive before using the fishing line.
