  • Member For: 15y 6m 17d
Posted
hey guys, long time reading, first time posting
I wanna know is there any difference between the n/a block and the turbo block?
also is the crank the same?
I know they have different rods, pistons and comp ratio
I'm looking at building up a hot turbo motor, new rods pistons etc...
just wanted to know if their the same because it'd save me a bit money to buy a long n/a motor than a turbo one
thanks
  • flame magnet
  • Legacy Donating Member
  • Member For: 18y 4m 20d
Posted
dunno?
maybe email your tuner?
or you could phone ford and see what the part numbers are respectively? if the same then- same/same.
  • Member For: 15y 11m 26d
Posted
The bit I know is that the block, and crank are the same. Only later BF that had updated rods(and FPV)
Pistons run a lower compression on the turbo motor.
So yeah, get a NA, and build up a goodun.
  • 5 months later...
  • Member For: 14y 6m 7d
Posted
I've just changed the engine and box in my ba
Changing from ba turbo to n/a bf was simple as everything bolted straight on including the tubo mannifold.
Wiring is the same except the bf has 2 knock sensors( just take one off)
the map sensor on turbo is 2 psi
the map sensor on n/a is 1 psi
But used same manifolds so nothing had to be changed.
Power is awesome
It doesn't have that lag off the mark like the turbo block and is very responsive on and off boost
Anyone looking for a turbo head?
  • Member For: 23y 9m 13d
Posted (edited)
Power is awesome
This is a VERY risky avenue, and should not be pursued.
There is a VERY high risk of detonation and leg out through the side, due to compression ratio being too high. This engine has to be pinging when floored, so a matter of time really :cry:
Edited by Ninka
Posted
U should read up on all specs
Pinging no
Percentage of turbo being spooled up in comparrison to previous engine is halved due to hvcia
U got any real experience on this topic or just trying to be a hero
Posted
Pinging no
I remind you of your status of 'Training Wheels' here
Amongst many other highly technical modifications to the BA/BF Falcon over the past 9 years, I have built 4 or 5 of these Turbo engines now, so if you do a bit of searching, I think you will find that I have a fair idea what I am talking about.
  • Like 3
