Spoony Member 250 Member For: 16y Gender: Male Location: Brisbane Posted 30/11/11 08:41 PM Author Posted 30/11/11 08:41 PM Seem to be going OK at the moment. I'm doing a skidpan day on the 10th, so we'll see after that haha.
Ralph Wiggum Moar Powar Babeh Legacy Donating Member 19,334 Member For: 21y 18d Gender: Male Location: Perth Posted 30/11/11 11:34 PM Posted 30/11/11 11:34 PM Im running another set of SPF1348k's (the comfort style with the full "turbulator" voids) No problems so far and I have given them a fair belting on a couple of cruises. I have the new trial bushes but will wait until the current set fail (or at least wait a few months if they dont seem to be failing) as I really dont feel like dropping the arse end out again. i dont think it can be stressed enough for both longevity of the bush and minimal increase in NVH how important it is too set the bushes at the correct depth in the subframe. The right depth will also reduce the angle on the CV'sYour best option install wise is to use a fulcrum suspension outlet (such as Wholesale Suspension Products in Sydney) as they have the right tools and Info too do it correct.You can set them up correctly at home but you need too take some measurements from the installed position of the old bushes and transfer this too the new ones once they are pressed in. You'll need too do a little maths as the bushes arent the same depth l/r or the same depth as the stock bushes.
turbotrana Member 2,586 Member For: 23y 6m 11d Gender: Male Posted 01/12/11 05:51 AM Posted 01/12/11 05:51 AM It seems that no one has addressed a proper solution for the diff bush. Whilst you can put a harder compound material in the bush, it really does not solve the problem. It just means the rear bolt gets more of a hiding.My solution is not easy and am not sure it would totally solve the problem or create a new problem but I would weld in a second bush along side the original bush.It would require a completely new hat welded up with locations for two bush bolts, the second bolt about 10cm to the drivers side of the original bolt. On the cradle you would weld in plates and tube to allow a second bush to be located next to the original bush.Now I have seen a few diff setups and most seem to have a 3 point mounting. I guess the single point is to allow for some twisting of the diff but am not totally sure. I have also seen 4 point mounting of the diff.Basically just convert it to a 4 point mounting with a bit of welding and maybe solve the problem once and forever. There is plenty of room under there.If the FGseries 2 has not addressed the diff then this is something I would consider doing down the track.
1600dave Legacy Donating Member 872 Member For: 15y 9m 1d Posted 01/12/11 09:00 AM Posted 01/12/11 09:00 AM Yeah the place I went to are a fulcrum dealer so I would assume would have the correct equipment. He seemed to know what he was on about and had the bushes in stock.Is there much difference between the comfort ones, and the trial ones they've given you?Ford are probably making too much money from not fixing the problem. Same thing with turbo's coming loose.
Ralph Wiggum Moar Powar Babeh Legacy Donating Member 19,334 Member For: 21y 18d Gender: Male Location: Perth Posted 01/12/11 10:47 AM Posted 01/12/11 10:47 AM Yeah the new trail bush only has two voids in it that are orientated vertically so there is maximum material under in the plane that cops all the torque loading
wa g6et Member 657 Member For: 15y 4m 8d Gender: Male Location: Perth NOR Posted 06/12/11 01:12 AM Posted 06/12/11 01:12 AM Do you know the outcome with the failed bush? Was there a manufacturing issue? Or was it fitment.
Spoony Member 250 Member For: 16y Gender: Male Location: Brisbane Posted 06/12/11 01:20 AM Author Posted 06/12/11 01:20 AM ^^ mine? As far as I was told, faulty batch of bushes, steel sleeve not glued properly to the bush.
wa g6et Member 657 Member For: 15y 4m 8d Gender: Male Location: Perth NOR Posted 06/12/11 01:51 AM Posted 06/12/11 01:51 AM (edited) ^^ mine? As far as I was told, faulty batch of bushes, steel sleeve not glued properly to the bush.Oh crap, I hope mine are ok and not in this batch.. A guy here in WA just had his centre superpro comfort bush let go on the weekend, from the photos looks exactly the same.I rang Fulcrum and there are no batch markings on the bushes, so it will be a bit hit and miss finding the faulty ones then.When did you have yours done? Mine was fitted here in Perth in July and then I guess the stock may have been sitting for a little while too. Edited 06/12/11 01:52 AM by wa g6et
senna_T Forged Member Legacy Donating Member 15,818 Member For: 19y 8m 4d Gender: Male Location: SW Sydney Posted 06/12/11 01:53 AM Posted 06/12/11 01:53 AM Roof had the comfort bush in his car, I think its done ok considering he is running big horsepower - but in saying that, yes you can get faulty bushes..
Corzza 777 Member 7,135 Member For: 17y 8m 10d Gender: Male Location: Neutral Bay. Born and Bred in the RSA Posted 06/12/11 02:17 AM Posted 06/12/11 02:17 AM Great conversation here guys.As mentioned to Senna several months ago I am due for rear bushes.Miguel who is on this forum and who has a FG F6 with 420+ RWKW went to go see Senna and the team and Wholesale suspension to sort his rear bushes out and they fitted up some Super-pro bushes at very good price. Miguel can not speak highly enough of the difference these made to his F6. So I guess it can can all come down to who installs them
