T6EGO Legacy Donating Member 91 Member For: 16y 5m 8d Gender: Male Posted 23/08/11 12:07 PM Posted 23/08/11 12:07 PM Hey guys. Just wondering anyone here installed a v3 rapids intercooler on ba/bf. Wondering whether cutting in bumper support needs to be made and does the air conditioner piping come in way of piping at all? Thanks
bjc Legacy Donating Member 2,823 Member For: 23y 1m 8d Gender: Male Location: Townsville Posted 24/08/11 01:13 AM Posted 24/08/11 01:13 AM Yes the bar requires cutting and the aircon lines need bending a fair bit.If you want to do it right then alot of cutting is required so that no piping or the intercooler rubs on anything otherwise if you want to be dodgy then just make some small cuts in the front bar and let the rest rub on the chassis!My experience anyway.
T6EGO Legacy Donating Member 91 Member For: 16y 5m 8d Gender: Male Posted 24/08/11 03:20 AM Author Posted 24/08/11 03:20 AM that's fair enough. So no Ac pipes needed removing though is that correct? Where is your piping connected too? Plenum? Back to crossover. Thanks
Henz Tampon inserted, Auto Acquired, next purchase a new handbag Legacy Donating Member 9,946 Member For: 18y 6m 21d Gender: Male Location: Vic Posted 24/08/11 03:41 AM Posted 24/08/11 03:41 AM It is possible, I just fitted my 1000hp plazmaman with no cutting. We moved the power steering lines upto behind the top grill.
T6EGO Legacy Donating Member 91 Member For: 16y 5m 8d Gender: Male Posted 24/08/11 03:56 AM Author Posted 24/08/11 03:56 AM Was it a big job to move steering lines henz?
bjc Legacy Donating Member 2,823 Member For: 23y 1m 8d Gender: Male Location: Townsville Posted 24/08/11 05:09 AM Posted 24/08/11 05:09 AM With the power steering line/cooler I moved mine closer to the radiator by bending and extending the brackets. As I said, you can fit it by not cutting but it will rub on just about every part. Steel beats alluminium and rubber for wear factor so give it 6-12months and I know what will win!As I said this is my experience as far as fitting the V3.5 kit.
sambo29 Member 58 Member For: 15y 3m 27d Gender: Male Posted 24/08/11 11:54 AM Posted 24/08/11 11:54 AM When I installed my hdi intercooler on my old bf, I also cut a fair bit of the bumper support and bent back the air con pipe, I suggest if you can do more cutting and less bending so everything has more room to move and bounce around I'd go with that option
T6EGO Legacy Donating Member 91 Member For: 16y 5m 8d Gender: Male Posted 24/08/11 12:07 PM Author Posted 24/08/11 12:07 PM Yer I figured. Just don't feel good about doing the cutting. Thanks for the replies..
GTEXXED Banned Banned 910 Member For: 14y 2m 21d Gender: Male Posted 18/08/12 11:01 AM Posted 18/08/12 11:01 AM Yes the bar requires cutting and the aircon lines need bending a fair bit.If you want to do it right then alot of cutting is required so that no piping or the intercooler rubs on anything otherwise if you want to be dodgy then just make some small cuts in the front bar and let the rest rub on the chassis!My experience anyway.Exactly what I found with my install.
