Jake F6 Legacy Donating Member 327 Member For: 23y 2m 10d Location: Melbourne Posted 28/07/11 01:09 PM Posted 28/07/11 01:09 PM Hi guys.I just bought a Manual 2008 FG F6 with 50,000kms on the clock.My current ride (which I will be selling shortly) is a BA MkII XR6T manual with 250rwkw.The plan is to mod th F6 to reach around the 300-320 rwkw mark, and my budget is around $5k. I will most likely be taking the car to Pitlane.The budget will be spent roughly as follows (please check if it looks ok):1. XCAL 3 and custom tune: $15002. Venom stainless 5' cat/dump pipe: $4503. Nizpro cooler pipe kit: $4504. XR8 intake & K&N filter: $1805. Cone replacement pipe: $150 (this is for noise only - does it make much difference?).6. Mal Wood Opt 3+ $18007. Replace centre muffler with straight pipes: $150 (this is for noise only).Am I missing anything?All of the above should keep the car and engine bay looking 100% stock, which is what I want. That's why I am reluctant to upgrade the intercooler.Also the car can be returned to stock tune simply by changing back to the stock cat/dump (is this easy?), and re-flashing.a) Is skipping the intercooler a mistake? b) Should I also look to get the replacement elbow pipe?c) Anything else?P.S. I will post pics up on the weekend.Cheers, Jake.
Henz Tampon inserted, Auto Acquired, next purchase a new handbag Legacy Donating Member 9,946 Member For: 18y 6m 4d Gender: Male Location: Vic Posted 28/07/11 07:59 PM Posted 28/07/11 07:59 PM I would be replacing the cooler, apparently the f6 one is no better than Xr ones. Also you shouldn't need a clutch at that level. 1500 xcal and tune2700 nizpro cooler, stainless 4" intake and battery relo. 450 your cat/ dump replacement100 muffler cut.
dre Resident idiot. Legacy Donating Member 2,068 Member For: 16y 4d Gender: Male Location: Melbourne Posted 28/07/11 08:04 PM Posted 28/07/11 08:04 PM What he said. Do the stainless intake, more power and it will give you the noise you want. The cooler kit from nizpro is good but at the power you want it might be a little over the top.
Dillz Three pedals are better then two.. Legacy Donating Member 15,637 Member For: 19y 3m 29d Gender: Male Location: Melbourne Posted 28/07/11 09:54 PM Posted 28/07/11 09:54 PM Bang on the money, except for the clutch.Maybe spend that on a cooler or full exhaust instead.
Roof Member 213 Member For: 18y 20d Gender: Male Location: Perth | Busselton Posted 29/07/11 04:32 AM Posted 29/07/11 04:32 AM Go the cooler before exhaust!Clutch is apparently ok up to 340-350kw at the wheels if you are nice to it, saying that I had problems with mine putting out stock power - launch testing couldn't be repeated after the first one. 1
f6mark Member 2,909 Member For: 15y 7m 10d Gender: Male Posted 29/07/11 06:54 AM Posted 29/07/11 06:54 AM mate. I did the pw stage 2 cooler and tune and got 320rwks with 15psi. this is with stock exhaust and stock injectors. fg f6 injectors r 42Ib/440cc so they r good for 320rwks mate. cheers mark.
Bomber Carnage on the Garage Floor Legacy Donating Member 3,994 Member For: 16y 4m 13d Gender: Male Location: Gold Coast Posted 29/07/11 09:34 AM Posted 29/07/11 09:34 AM (edited) Mate the PWR Stepped cooler involves no cutting and would be a nice upgrade for the power you're chasing. $990 for the cooler and $430 for a coolerworx pipe kit to suit. That with your cat upgrade will land you 320rwkw all day. Edited 29/07/11 09:37 AM by bomber
g6t Legacy Donating Member 328 Member For: 16y 5m 8d Gender: Male Location: sunshine state Posted 30/07/11 01:39 AM Posted 30/07/11 01:39 AM as f6mark said above same car. 1
Snapper Legacy Donating Member 320 Member For: 15y 5m 5d Gender: Male Posted 30/07/11 03:05 PM Posted 30/07/11 03:05 PM I am in the same boat thinking of what to do...And the limits of the componentsWhat would be the next stage for the f6 Thinking of more 330kw close to 380kwinjectorsFuel pumpAny turbo mods neededthanks
Jake F6 Legacy Donating Member 327 Member For: 23y 2m 10d Location: Melbourne Posted 01/08/11 01:59 AM Author Posted 01/08/11 01:59 AM Thanks guys!It's awesome to get this detailed level of advice.So I think that from the consensus above, my list will be as follows:1. XCAL & Tune $ 15002. Herrod cooler pipes $ 4503. Venom Cat/Dump $ 4504. XR8 intake & K&N $ 2005. PWR Stepped cooler $ 9506. Centre muffler chop $ 150TOTAL $ 3700I will keep an eye on the clutch, but will budget for a Mal Wood Opt 3+ down the track.I won't worry about the elbow pipe. To get the car back to stock tune, it will mean a visit to a workshop to remove cooler and dump/cat pipe and reflash back to stock.No need for valve springs, actuator, and turbo porting I guess at this level?// Jake.
