  • Legacy Donating Member
  • Member For: 16y 8m
Posted
If you do a major revamp of the exhaust and intake and free up all those restrictions you should be able to get decent power on a lowish boost which imo is the best way to treat it. 16psi that is alot, didnt even run that in my subie.
  • Member For: 15y 8m
Posted
Can't argue with that :)
I have taken a few pics of what I have been doing. repower and plenum pics
At least I am back on the road now and can tow the boat.
I know the plenum is not textbook but it seems to give me plenty of low down torque with very little delay. I opted to put the throttle body on top so flow would be even 3 cylinders each side. I also did a screwdriver job on the cat.
I am running the standard BF tune from when I bought the car and it seems way different. I even get a better, clean sound from the bov which vents to atmo.
I will be getting a tune next week and wanted to know if the BA T is the same motor as the ZF T pre 06/06. My mate has an early BF that goes real well so was going to transplant that tune with a few adjustments on the boost to compensate for the gutted cat.
What is the max boost I can safely run?
Will up a pic of the completed job soon.
  • Member For: 18y 5m 5d
Posted (edited)
Mine runs 15psi has a gutted cat (screw driver also) and the rest of the nizpro gear and I've never had a problem with it (touch wood) and I don't nana it...Your new plenum looks kinda similar to the FG plenum..
Edited by xr6turboman
Posted
Id just see what power you get without pushing it too much, the tuner should know what kind of boost is safe. Rather than aim at a boost level that is.
Interesting plenum, good job.
Posted
I notice on the Nizpro site it says "Note: MkII BF and F6 models don't require Cobra valve springs or conrods to be fitted"
So you have a BA right? and the springs and rods aren't fitted?
I might have to get the spanners out again and put my 60lb'ers and 12.7psi actuator back in ready for the tune next week. I really would love to know what a safe power level is.
At least my engine is easier to work on now and I'm getting plenty of practice :P
Posted
Yea mate BA II they do have beefer LPG rods (I think) over BA's but pretty sure max is about 350rwkw and no I don't have valve springs or rods but will do valve springs pretty soon as I do get some float if I rev to high... also I havn't done the actuator either my average 3" exhaust holds everything back so I make max 15psi and it tapers down to about 12.. yea I helped a mate with all the plenum and intercooler battery relocation so kinda know my way aroudn the engine as well..
  • Member For: 15y 10m 27d
Posted
post 06/06 have the typhoon rods. all ba's and early bf's have the smaller rods. there is a lot of guys in ba's with around 340/350rwks. it all comes down to the tune/tuner. with your next engine just put spool rods and cp pistons. get onto the spool website, they have the rod and piston kit for about $1700. or go on the forum classified's someone is selling a rod and piston kit on there.
Posted
Cheers for the info. For the Spool engine kit with freight and dollar conversion and GST I would be looking at about 3k which I don't think the mrs will go for atm.
Maybe I could just put my 60lb injectors back in for safety and leave the stock actuator in place to keep boost down and see what results I get?
I will look into that gear in the classifieds, thanks :)
Posted
Oh god that's tempting .. I'm just about to get back from afgan so I'm all det free and have some cash sitting in the bank burning holes haha I've already spent like 5-6k on the car since I've been over ehre.. clutch + short shift gauges some bling for the engine bay eew and I wanna do some valve springs .. just the things ya gotta do after spending 6 months in a sh*t hole haha.. :stirthepot:
Posted
Hey mate, you go for it if you're talking about the gear in the classifieds. I can't see myself being flush for a few months yet anyway :)
