Revenge Member 9 Member For: 17y 11m 24d Posted 13/02/11 06:18 AM Author Posted 13/02/11 06:18 AM Also can someone tell me what stock boost level is?
Pazzo Legacy Donating Member 11,132 Member For: 15y 11m 1d Gender: Male Posted 13/02/11 06:19 AM Posted 13/02/11 06:19 AM I have a bf mk2 and in the handbook if the mil light comes on its got to do with emissions and cat converter. this is how its written in the book.[ if the MIL is constantly illuminated when driving, this indicates the vehicle is no longer operating within the emission regulationsand the vechicle should be taken to the nearest ford dealer ]. as long as its not flashing every 1 second and if it is will damage cat converter. hope this helps. mine did it and it was the second o2 sensor.
Rudiger All round good guy! Legacy Donating Member 1,122 Member For: 18y 4m 14d Gender: Male Location: Greenvale, Victoria Posted 13/02/11 07:42 AM Posted 13/02/11 07:42 AM I think they run about 3 pound of boost or it may be 6. I cant be sure. It is bugger all though.And Revenge mate, while I'm not having a go at Turbonator, you can expect a heap of sarcasm here. Its all in good fun, honestly. God help you if you ask a dumb question inadvertantly. OUCH!!. I have now and then and WHAM. Get hit for six.I can sense your frustration, but its true. While we bad Ford, there are actually a few dash lights that mean something. If my engine light or brake fail light came on it would be poo poo time for me.Anyway, whatever you do, make sure you let us know what the fault was.Bye the way, Tab is the man. He is probably on the money.
Revenge Member 9 Member For: 17y 11m 24d Posted 14/02/11 02:06 AM Author Posted 14/02/11 02:06 AM Right so the car is booked in tomorrow, will update this thread regarding the outcome by Ford. Hopefully this will help others in the future.
Wenier Legacy Donating Member 1,736 Member For: 16y 8m 5d Gender: Male Location: Christchurch, New Zealand Posted 14/02/11 02:44 AM Posted 14/02/11 02:44 AM My BF2 manual runs 4.3lbs from low in the revs to 4000-4500 then peaks up to 6lbs for the 4500-6200 range.
The_Bogan Legacy Donating Member 881 Member For: 19y 5m 20d Gender: Male Location: Brisbane, Queensland Posted 14/02/11 06:41 AM Posted 14/02/11 06:41 AM im plugging my scantool into the computer but its not connectingmate I need you to back your ute up to the computer screen so that I can connect it and properly diagnose the cause of your engine light!!! I would be getting the light looked at before you post it up here mate. could be litterally a million reasons as to the cause
jono Member 84 Member For: 18y 4m 4d Posted 14/02/11 11:05 AM Posted 14/02/11 11:05 AM I reckon its stuffed and needs to go to car heavenMass Air sensor, big ends, little ends, the puffer valve and the oil cap will all be stuffedNow you will also have to check the washer bottle cause that's sure to gotten lose and the third nut on the left hand front wheel is probabley missing as well.Apart from that all should be good .
Revenge Member 9 Member For: 17y 11m 24d Posted 15/02/11 11:49 AM Author Posted 15/02/11 11:49 AM (edited) UpdateSo today the car was booked in at Ford and after about 10mins they diagnosed 12 fault codes, 8 of them referred to 4 main codes which I have listed below.Fault 1 – One or two oxygen sensors (one looks like the wires are too close to the heat shield which have melted causing the below fault) Fault 2 – Heater circuit, HEGO fuse blown (pretty simple replace fuse once fixed)Fault 3 – Waste gate not operation correctly (not boosting to set level)Fault 4 – Default max fuel setting (resulting in default MAP/ ECU setting safe mode)I am happy regarding the above outcome as these things are very easy to fix. In saying that the fact that the car wasn't running 100%, means once fixed the 1/4 mile times and MPH should improve. Edited 15/02/11 11:52 AM by Revenge
jono Member 84 Member For: 18y 4m 4d Posted 15/02/11 01:16 PM Posted 15/02/11 01:16 PM Whate about the left wheel nut
