  • Inactive Members
  • Member For: 16y 6m 22d
Posted
hi guys, I have a 2003 manual xr6 turbo, standard no mods , last night I noticed as I went to overtake a car , I put it back into 3rd and put the foot down, and it took off but as soon as it hit 3500 4000 ish it just cut out like it was breaking down under load?
its drives fine and still boosts but under load its like traction ctrl but the light doesnt flash ,
I tried some differnt coil packs, new plugs
any ideas would be great
cheers matt
  • BOOST
  • Moderating Team
  • Member For: 23y 1m
Posted
Valve springs?
  • Legacy Donating Member
  • Member For: 18y 4m 28d
Posted
fuel pump may be on the way out. Or clogged fuel filter.
  • 2 weeks later...
  • Banned
  • Member For: 17y 6m 14d
Posted (edited)
maybe a loose intercooler pipe.. Also fuel surge, Put a full tank in and see if it make's a difference
Edited by mad_rx2
  • Member For: 17y 7m 11d
Posted (edited)
It sounds like exactly what my car used to do. I took it to C&V Performance and they said the coils were stuffed so they went out and got me new ones (stock from ford I think). They also replaced my spark plugs. This was at least 6 months ago. Havn't had the problem since.
Edited by ljm
  • Member For: 17y 10m
Posted
Check the hoses to your boost solenoid are both connected & tight (clean out the boost solenoid & hoses while you're there with WD40).
Replace your fuel filter & ensure your new coils are firmly pushed on.
Let us know how you go.
  • Member For: 19y 6m 2d
Posted
sounds like plugs and coils mate!!!
  • 3 weeks later...
  • Member For: 17y 2m 6d
Posted
Had the same problem on My car and it is also a 2003 BA Just changed the Fuel filter and bought standard plugs and gapped them to 0.7mm Plugs were like $4.80ea and problem solved, I just get Valve bounce over 5000 RPM now on boost, Guess my Valve springs are farked haha :-)
