  • Member For: 17y 5m 11d
Posted
Hi guys.....Ex police chaser F6's does anyone know if they are tuned up or anything??? I still havent dynoed it. also im in a bit of a pickel atm cause I went to change the spare 19'' wheel for the front left cause I noticed that the front left has worn down to the canvas big time in nice thin strip....which tells me that cause the police lower em they dont fix tha bad camber in them....not to be outdone I went to get the spare and it was worse to the point it was BLOWN....as I only have had the car for two weeks I rang the dealership where I bought it from and spoke to the dealer manager and the comment I got was "Well you bought the car as is" "I shouldnt have to do anything" ..... im like WTF? so I burred up and went off....to then he said " Let me talk to my boss and I'll call you back" I still havent heard from them! any ideas?
  • Replies 30
  • BOOST
  • Moderating Team
  • Member For: 23y 13d
Posted
Short answer. No they arent stock as a rock.
The only thing that would make them lower is all the crap they have to cart around.
Stock power. standard ride height
  • Sucker
  • Moderating Team
  • Member For: 22y 4m 25d
Posted
If you purchased it registered from a dealer then it has to be roadworthy...take it back and have a tantrum.
  • Legacy Donating Member
  • Member For: 18y 9m 25d
Posted (edited)
They are run in very well - I've just run a 13.59 in an 07 XR6T in manual mode on the ZF auto - only mods are f6 intake and K&N panel filter, first time ever at the strip. 105mph too!
I put it down to them not babying it from new as I've read that slows an engine down. Gives rise to the "police tune" myth I reckon.
As for your wheel being down to the canvas and the spare being blown - that would surely be their responsibility to make roadworthy at sale as tab said!
Edited by -SteveR-
  • A much better forum
  • Member For: 18y 1m 27d
Posted
13.59 stock is good... But not special... It's right on where it should be... Not all police chasers would bef logged non stop...
Some guys have run 13 flat stock in bfs...
Posted (edited)
From reading the forums I was hoping for 13.8 so I'm pretty happy :w00t2:
Mine's not a 'chaser' as such, story goes it was a tow car. Same diff though!
Edit... Maybe if I could drop .3 from my 60' time, but I'm way too green for that sort of magic yet! Modding soon anyway muahaha...
Edited by -SteveR-
  • Member For: 19y 10m 3d
Posted
None of the Police HWP vehicles are tuned up. The new XR6T's have a brembo brake package, that is it.
Each new model has to undergo extensive crash and stability testing with all the kit and 9 times out of 10 it is the brakes that fail.
Only mods done on the BF's were capacitor for all the electrics and Ultimate Bendix pads.
There is no chip, boost, box, suspension etc mods done.
Fords run Dunlops, Holdens run Potenza.
Holdens did get optioned with the FE2 suspension, that is IT!
All cars are flogged, bounced over stuff, driven and braked hard, only way job can be done, however every car is serviced and repaired VERY well as you have to trust your life in what is essentially a family car with flashing lights.
Just imagine a coroners inquest explaining why such and such was boosted up, over powered etc, contributing to a loss etc. Not going to happen, never has.
  • Member For: 20y 9m 9d
Posted
car has to be roadworthy, just call dept of fair trading and they will call the dealer on your behalf.
as for mods done to them I have delivered more then 60 xr6 and f6 to the police in NSW and all of them have been stock except the BA and BF had bigger brakes and the speedo on the dash was in 2km not 5km. this is an easy way to check if it is an ex chaser.
not sure about FG as I am now back in retail.
  • Member For: 18y 10m 10d
Posted
Seems common for inside of front tires to chop out early if the pressures are not kept ideal, my eagle f1's chopped out on the left front due to a slow leak causing a constant drop in pressure. When we replaced the tires we found a manufacturers sticker on the inside of the rim at the bead which had caused the tyre to be unable to seat airtight.
  • Member For: 21y 8m 3d
Posted (edited)
Whilst the cars are delivered stock, sources in government told me that they were led to believe, and they could be mislead, that, enterprising police officers seeking superior performance in the line of duty, have become versed in the art of, '...adding chips to the cars'...
Regards,
aa
Edited by aiboart
