  • Member For: 18y 9m 10d
Posted
hey guys I just noticed that my front bumper seems to be sagging a bit. the passenger side around the light seems to have dropped about 1cm and theres an obvious gap between the bumper and the light assembly now. how the heck did this happen?? I havent hit anything. prehaps the clips have broken?? if this is the case...where would I get new clips from?
  • Legacy Donating Member
  • Member For: 23y 1m 2d
Posted
This tends to be the case on most B series. Mine sagged before I removed it for mods and is worse now. CBF fixing it though as it will be removed again one day.
Do a search as I know someone on here put up a 'How to' on fixing this issue as best as possible.
  • Member For: 17y 5m 6d
Posted
I have a BA and noticed it on mine as well..all my clips were in and nothing was broken. When I did my lights I removed bumper then when I put it back on the sag was still there...maybe just a design problem??? :nono:
  • Member For: 17y 9m
Posted
Take off the number plate and put a self tapping screw through the hole that is in the middle of the bar. Stopped mine from sagging.
Posted
That could have been the fix, cheers for that Ben.
  • Member For: 19y 4m 10d
Posted
Deal with it pretty much. that's about all you can do.
  • Need more power. Now taking donations.
  • Member For: 17y 7m 9d
Posted
I fixed mine by removing the bar, and the the plastic clip assembly at the sides was removed, drilled to allow adjustment where the screws are and tightened slightly higher. Clipped it back on and problem was fixed.
Posted
You sound like me Dillz, CBF...lol
Posted
True dat!
I fixed the problem by selling the XR but now I have an EL with a saggy arse! Go figure.
Posted
riteo. I could just leave it but it seems to be getting worse. I dont want to hit a pothole and the whole bumper falls off!
