Pete A Member 442 Member For: 17y 9m 26d Gender: Male Location: Castle Hill NSW Posted 21/10/09 01:36 AM Posted 21/10/09 01:36 AM For stone chips, just use the Ford touch-up paint. For larger areas get a panel shop to do it because despite the claims, the Autobarn and other speed shop touch-up paints do not match. Probably depends on the colour. But I had Mandarin, and the stuff I bought from Supercheap was supposed to be Ford Mandarin and the code matched, and it could not have been worse. I eventually took it to a paint shop and it was perfect, even if it cost me considerably more.
ENVI.BA Member 146 Member For: 17y 9m 17d Gender: Male Location: 2155 Posted 23/10/09 02:29 AM Posted 23/10/09 02:29 AM hi NVTWere you able to get touch up paint ?would you know the colour code for Envi?
xr6turboman Legacy Donating Member 588 Member For: 18y 5m 16d Gender: Male Location: New Zealand, Palmerston North Posted 23/10/09 03:46 AM Posted 23/10/09 03:46 AM Colour code should be inside the drivers door somewhere... or under the bonnet by the PCM
XtRmn8 570Nm @1800rpm Legacy Donating Member 2,441 Member For: 23y 7d Gender: Male Location: Perth, WA Posted 23/10/09 04:08 AM Posted 23/10/09 04:08 AM Colour code should be on the build plate and Just go to Ford spare parts and they will have touch-up paint for about $10. Just don't expect them to match too well unless your car is white or black.
berzerker Legacy Donating Member 767 Member For: 18y 9m 8d Gender: Male Location: Brisbane Posted 23/10/09 04:24 AM Posted 23/10/09 04:24 AM Yeah XtRmn8 is right, dont expect it to match, I remember when I got some for my maroon AU falcon, it was WAY darker..
ENVI.BA Member 146 Member For: 17y 9m 17d Gender: Male Location: 2155 Posted 23/10/09 05:37 AM Posted 23/10/09 05:37 AM thanks..... nah mine is in envi too...I swiped a kerb and did the back wheel and nicked the side skirt a bit so its a little inconspicuous but still want to touch it up
discostig Manual mode ________________________ All day, erryday Legacy Donating Member 13,798 Member For: 18y 10m 4d Gender: Male Location: Probably above atmospheric pressure Posted 23/10/09 05:45 AM Posted 23/10/09 05:45 AM Lightning strike touch up paint has so far left me unimpressed on a large chip I got on my bonnet. Probably needs a sand back and clear though.....
Chich Damn You's A Sexy Chich Member 3,843 Member For: 18y 7m 13d Gender: Male Location: Your House Posted 23/10/09 06:02 AM Posted 23/10/09 06:02 AM (edited) touch up paint will almost never match exactly, its more just a bit of a cover up, and handy to cover any chips that may be either obvious or exposing metal,(to avoid moisture getting beneath the paint and causing a much larger problem) only true fix is to have it done by a professional, which will generally mean painting.I know there are some guys who get around in vans doing small touch ups, not sure how good they are or if they match it perfect or whatever, but maybe worth a shot... Edited 23/10/09 06:02 AM by Chich
