Kingers. Member 227 Member For: 15y 4m 8d Posted 29/01/11 01:40 AM Share Posted 29/01/11 01:40 AM ok so guessing the fuel tank steps down or something where the pump is, kinda thought it might do that, slowly undid a 2 screws and fuel started to come out so closed it back up. couldnt even get the F@#%ing fuel lines off anyway, going for drive tonight to hopefully drain the tank abit, is there any trick to these suckers? push the tabs on the side while pushing forward then pull back aint working for me, lol Link to comment https://www.fordxr6turbo.com/forum/topic/58327-sedan-fuel-pump-install-how-to/page/6/#findComment-1076394 Share on other sites More sharing options...
XAH03 Member 597 Member For: 17y 8m Gender: Male Location: Cairns QLD Posted 29/01/11 04:22 AM Author Share Posted 29/01/11 04:22 AM Haha yeah the tank has to have bugger all fuel in it, mine was just above empty.With the fuel lines, push it forward then squeeze the tabs in and pull back it should let go. They are a bit of a pain in the a$$ but you'll get them with a bit of swearing. Link to comment https://www.fordxr6turbo.com/forum/topic/58327-sedan-fuel-pump-install-how-to/page/6/#findComment-1076439 Share on other sites More sharing options...
Kingers. Member 227 Member For: 15y 4m 8d Posted 29/01/11 04:39 AM Share Posted 29/01/11 04:39 AM just cant seem to get the tabs to push in good enough, gonna try with some pointy nose pliers or something tomorrow. I take it the tabs stay on the cradle and they dont slide off as well? Link to comment https://www.fordxr6turbo.com/forum/topic/58327-sedan-fuel-pump-install-how-to/page/6/#findComment-1076447 Share on other sites More sharing options...
XAH03 Member 597 Member For: 17y 8m Gender: Male Location: Cairns QLD Posted 30/01/11 01:38 AM Author Share Posted 30/01/11 01:38 AM are you talking about the fuel line tabs that need to be disconnected before the cradle comes out of the tank or the tabs on the side of the cradle for it to seperate?? Link to comment https://www.fordxr6turbo.com/forum/topic/58327-sedan-fuel-pump-install-how-to/page/6/#findComment-1076679 Share on other sites More sharing options...
Kingers. Member 227 Member For: 15y 4m 8d Posted 30/01/11 02:15 AM Share Posted 30/01/11 02:15 AM The tabs for the fuel line tabs that need to be dissconnected before the cradle comes outa the tank, tried again today. Easier to pay someone to do it, lol Link to comment https://www.fordxr6turbo.com/forum/topic/58327-sedan-fuel-pump-install-how-to/page/6/#findComment-1076695 Share on other sites More sharing options...
XAH03 Member 597 Member For: 17y 8m Gender: Male Location: Cairns QLD Posted 30/01/11 03:19 AM Author Share Posted 30/01/11 03:19 AM yeah they are a pain. you have to push them forward, squeeze the tabs then pull back and they should release. did you get the fuel out of the lines before you tried to undo them? Link to comment https://www.fordxr6turbo.com/forum/topic/58327-sedan-fuel-pump-install-how-to/page/6/#findComment-1076713 Share on other sites More sharing options...
Kingers. Member 227 Member For: 15y 4m 8d Posted 30/01/11 01:43 PM Share Posted 30/01/11 01:43 PM yeah tried for awhile but they wouldnt budge, over it now, ill just pay someone. Yeah pulled the fuse while car was running to get the fuel out the lines Link to comment https://www.fordxr6turbo.com/forum/topic/58327-sedan-fuel-pump-install-how-to/page/6/#findComment-1076891 Share on other sites More sharing options...
circusmonkey89 Member 5 Member For: 14y 7m 8d Posted 14/02/11 08:51 AM Share Posted 14/02/11 08:51 AM Does that interior area with the soldered wires become flooded with fuel??I'm thinking of soldering too, but I don't think the heatshrink would be rated for fuelThere is heat shrink out there that has a particular glue on the inside. When it shrinks on your cables it becomes airtight. Ask an electrical supplier like haymans. I have only seen it used on larger cables so getting something smaller might be difficult.In any case it is a much better option then crimping. Link to comment https://www.fordxr6turbo.com/forum/topic/58327-sedan-fuel-pump-install-how-to/page/6/#findComment-1081004 Share on other sites More sharing options...
Kingers. Member 227 Member For: 15y 4m 8d Posted 18/03/11 09:56 AM Share Posted 18/03/11 09:56 AM Ok finally found away to get the suckers off haha I used 4 flatblade screwdrivers, small ones. I used them on the inside of the connector and gentally lifted all 4 of the locking tabs and it slid off very easily seems a lot easier this way. I recommend people who are having trouble toGive this a go. You should be able to see all the tabs that clip over that need to be lifted Link to comment https://www.fordxr6turbo.com/forum/topic/58327-sedan-fuel-pump-install-how-to/page/6/#findComment-1089999 Share on other sites More sharing options...
locknut Member 26 Member For: 15y 9m 13d Gender: Male Location: Canberra, ACT Posted 18/04/11 01:30 PM Share Posted 18/04/11 01:30 PM Strongly advise against this, as you can damage the tabs. Admittedly I've had a couple of issues with the submersible line being too long, and pushin the cap up etc.. and have had to take the pump out a couple of times. I was using drivers, and being carefull, but the claw-lip on these tabs that hold on to the rib of the male fitting can be damaged easily, and the supply line can blow off; which is what happened to me last week. I had to replace the line with a new supply line:Just slide the fitting forward, then slide the tabs back, and the fitting will come off with ease.Mine is leaking, and people are saying there's a seal, but no pics. I fit the module into the tank, and put the black metal ring on top, 6 bolts. I don't have any rubber seal? Link to comment https://www.fordxr6turbo.com/forum/topic/58327-sedan-fuel-pump-install-how-to/page/6/#findComment-1097967 Share on other sites More sharing options...
