trickdoubt Member 25 Member For: 17y 7m 22d Posted 11/03/09 11:31 AM Posted 11/03/09 11:31 AM hey guys got some issues with my 03 xr6t 4spd auto... current mods are after-market fmic(1) pull up to a set of lights car gets a rough idle and 9 times outta 10 it stalls and wont start easily...(2) 3rd gear car wont rev past 4250rpm (starts to spit n sputter)(3)zero power compaired to my dads xr6t (100% stock) any help would be greatly appreciated
seventytwo Still have a turbo, it's just on a diesel. Legacy Donating Member 5,368 Member For: 21y 2m 13d Gender: Male Location: The 8th Dimension Posted 11/03/09 11:34 AM Posted 11/03/09 11:34 AM Block fuel filter would be my guess or a fuel pump on the way out.
Superdan Well-Hard Bangin' Member Member 3,422 Member For: 19y 1m Gender: Male Location: Perff, WA Posted 11/03/09 11:46 AM Posted 11/03/09 11:46 AM yeah we have issues with 03XR6T too But seriously, has the car been tuned?
trickdoubt Member 25 Member For: 17y 7m 22d Posted 12/03/09 03:13 AM Author Posted 12/03/09 03:13 AM not that I know of!!!
Guest Guests Posted 12/03/09 03:22 AM Posted 12/03/09 03:22 AM yeah we have issues with 03XR6T too Suck a big one Dan...trickdoubt, if you're car isn't tuned & you have a decent cooler on it there's a good chance you're overboosting. that will cause the car to run rough at higher rpm because there isn't enough fuel in the Air/Fuel mixture...This will also cause your rough idle after a quick squirt. You now have increased air flow coming in through your intake system & into your engine, but no where for it to go due to the stock exhaust (namely stock cat) in place. This means that the valves can't fully shut as the stock valve springs aren't upto the task. Hello valve float!Two options:1. Replace aftermarket cooler with factory unit.2. Get a tune to suit the new cooler. This is a waste imo as you would really want to get injectors, pump & cat to optimise the tune/cooler combo.My advice would be to either fork out for tune, squirters, pump & cat to get a safe/repeatable 280 - 290rwkw or return to stock.Hope this helped
trickdoubt Member 25 Member For: 17y 7m 22d Posted 12/03/09 03:45 AM Author Posted 12/03/09 03:45 AM cheers for all your help guys, been thinkin bout wen the issue started n it was bout the same time I put the cooler on...so at the moment the car goes in april for a manta 3" exhaust turbo backflash tune then a run on the dyno to c how everything goes!!!
Superdan Well-Hard Bangin' Member Member 3,422 Member For: 19y 1m Gender: Male Location: Perff, WA Posted 12/03/09 12:58 PM Posted 12/03/09 12:58 PM Excellent, make sure you come back and post up how she went!!
The_Bogan Legacy Donating Member 881 Member For: 19y 5m 17d Gender: Male Location: Brisbane, Queensland Posted 14/03/09 07:21 AM Posted 14/03/09 07:21 AM coil packs and plugs I would say.
trickdoubt Member 25 Member For: 17y 7m 22d Posted 14/03/09 01:06 PM Author Posted 14/03/09 01:06 PM so the issues just got worse car wont rev past 3000rpm in all gears now... plus the fact that the underside pannel decided to detatch itself witch also took the front bumper off... so with everything that went wrong in those few minutes has got me thinking about selling the turbo, paying out the loan n gettin an el falcon!!!
