104ord Member 391 Member For: 18y 6m 15d Gender: Male Location: north brisbane Posted 20/11/08 10:36 AM Posted 20/11/08 10:36 AM cant we all just get along.....get a button clutch, hold it at 2800 and get off it... hold with the wheelspin and flat change into second, wheelspin galore... go the n/a, mine was n/a for a while and it was good sitting at a set of lights and being confident that I would beat the daewoo matiz beside me... the only problem was when a daewoo nubira would pull up beside you ..and then you knew you had a race on your hands...... the memories
typhoon_freak Cryptic Clothing Company Legacy Donating Member 4,556 Member For: 18y 2m 22d Gender: Male Location: Brisvages, Capalaba Posted 20/11/08 07:54 PM Posted 20/11/08 07:54 PM lol neways.. I used to have a xr6 ute n/a and I ended up puttin in a heavy duty clutch, full exhuast system, bigger throtlebody, tune and different diff and it use to just slightly pull away from a stock T... still remember the look on the guys face... but geting a T and start to mod that... theres no comparison... I used to hold it around 2500-3000 rpm.. and feed the clutch out to a little bit of wheel spin.. not enuff to stand still.. just enuff to have traction.. and your off! of go buy a stall convertor
brett_xr6 Member 61 Member For: 18y 4m 15d Posted 21/11/08 12:09 AM Author Posted 21/11/08 12:09 AM lol neways.. I used to have a xr6 ute n/a and I ended up puttin in a heavy duty clutch, full exhuast system, bigger throtlebody, tune and different diff and it use to just slightly pull away from a stock T... still remember the look on the guys face... but geting a T and start to mod that... theres no comparison... I used to hold it around 2500-3000 rpm.. and feed the clutch out to a little bit of wheel spin.. not enuff to stand still.. just enuff to have traction.. and your off! of go buy a stall convertorThanks,This may sound silly, but I thought stall convertors were just for Automatic cars? If they are for manuals how do they work?
typhoon_freak Cryptic Clothing Company Legacy Donating Member 4,556 Member For: 18y 2m 22d Gender: Male Location: Brisvages, Capalaba Posted 21/11/08 05:42 AM Posted 21/11/08 05:42 AM oops sorry.. my bad.. I thought I read 6spd auto for sumreason, I know in the zf, launch control can be set thru edit but umm maybe look into button clutches..
XRPete Member 673 Member For: 19y 22d Gender: Male Location: Here Posted 21/11/08 06:06 AM Posted 21/11/08 06:06 AM \I used to hold it around 2500-3000 rpm.. and feed the clutch out to a little bit of wheel spin.. not enuff to stand still.. just enuff to have traction.. and your off! of go buy a stall convertorHAHAHAHHAA you thought it was an auto,but you still mention feeding the clutch out
typhoon_freak Cryptic Clothing Company Legacy Donating Member 4,556 Member For: 18y 2m 22d Gender: Male Location: Brisvages, Capalaba Posted 21/11/08 06:28 AM Posted 21/11/08 06:28 AM *note.. it was 5 am... brain dont function too well in the morn
jonesy_87_ Member 37 Member For: 18y 4m 7d Posted 22/11/08 10:39 PM Posted 22/11/08 10:39 PM Quick question.Does anyone else witha BF 6 speed gearbox get a loud clunk when doing quick changes from 1st to 2nd? Ie, quick change, dump clutch...Cheers
brett_xr6 Member 61 Member For: 18y 4m 15d Posted 23/11/08 10:21 AM Author Posted 23/11/08 10:21 AM Mine was making a very loud clunk when changing, which turned out to actually be all 3 of my diff bushes. They had all craked in half, which was not good. Even after the car has been repaired under warranty it still makes a clunking noise. Its just they way the car is setup. Its by no means perfect or smooth, but you would have a hard time breaking that gearbox. Its as tough as nails.
jonesy_87_ Member 37 Member For: 18y 4m 7d Posted 24/11/08 07:45 AM Posted 24/11/08 07:45 AM Mine was making a very loud clunk when changing, which turned out to actually be all 3 of my diff bushes. They had all craked in half, which was not good. Even after the car has been repaired under warranty it still makes a clunking noise. Its just they way the car is setup. Its by no means perfect or smooth, but you would have a hard time breaking that gearbox. Its as tough as nails.Awesome!I had my diff bushings replaced under warranty too. Just wanted to make sure that someone elses 6speed was clunky!!I still find that 1st to 2nd can be notchy and shaky going through the gate while all my other gears are perfect.When the car warms up it seems to be a bit better.Might get it looked at under warranty next service.
brett_xr6 Member 61 Member For: 18y 4m 15d Posted 24/11/08 11:56 PM Author Posted 24/11/08 11:56 PM Until the car warms up a little you have to be pretty tame with the clutch otherwise you will hear a lot of noise out of the gearbox. I've even noticed that trying to drive at 20-25 through a carpark can be a nightmare. It sometimes likes first other times it likes second, but will usually hop and jump around in each. You feel like an idiot, but its just the way the box is. From the outside it must look like a L plater on its bad days. The trade off is that it is not smooth, but in return its virtually bullet proof.I'm still having trouble trying to make a nice smooth quick downshift on the highway from either 5 or 6 back into 3 where the power zone is. You have to be gentle otherwise it won't slot into the gate. From 5 I have to pull back towards neutral ease the pressure on the stick and then go again for a quick change into 3rd. If I am lucky it is sometimes smooth.......I wish it would let me do a complete swing action.
