Kingxr6T Member 9 Member For: 18y 1m 2d Gender: Male Location: Singleton nsw Posted 18/11/08 03:51 AM Posted 18/11/08 03:51 AM Just putting the question out there to see if any one has had trouble with the radio reception in a fg xr6t ute?My ford dealer cant fix it and its pissing me off..
smicky Go Pies!!! Legacy Donating Member 2,852 Member For: 18y 7m 13d Gender: Male Location: Vic Somewhere - Sometimes NSW Posted 20/11/08 01:17 AM Posted 20/11/08 01:17 AM (edited) ill just drill a hole in my roof shall I??Read above - rear windscreen.... u dont need to drill anything...Why dont u go to jaycar or a car audio place and take a look around - talk to someone there and find out before you act like a know it all that doesnt need to have asked the question in the first place!Gees man! I was referring to say one idea- running a antenna say through your side pillar and there should be a little grommet - take the cable through there and around to the rear windscreen, use a glue on/self adhesive antenna on the out side of the glass...Yes drilling a hole in your car body is one solution (prob not the roof however), and adding a conventional type would increase your reception... But not the best recommendation if you dont wish to cut the body!You will find that there is no need for drilling at all if you try a different solution... Hence my above recommendation...If jaycar no longer have this type of antenna try a car audio place... simple... and should cost more then about $50...Looks like this : Edited 20/11/08 01:21 AM by smicky
Trough Lolly Member 4,349 Member For: 22y 21d Gender: Male Location: Mildura Posted 20/11/08 05:54 AM Posted 20/11/08 05:54 AM its ok man... I used a 20ft UHF aerial I got from a guy at a garage sale.works a treat!
RHR BOOST Moderating Team 5,698 Member For: 23y 24d Gender: Male Location: Southern Highlands NSW Posted 07/12/08 11:41 AM Posted 07/12/08 11:41 AM Is there a fitting or plug in the rear of a sedan that can come loose. Mine was working and now its sh*t
smicky Go Pies!!! Legacy Donating Member 2,852 Member For: 18y 7m 13d Gender: Male Location: Vic Somewhere - Sometimes NSW Posted 08/12/08 03:01 AM Posted 08/12/08 03:01 AM Is there a fitting or plug in the rear of a sedan that can come loose. Mine was working and now its sh*tYep!Mate there is... its behind the passenger side plastic panel which is push cliped and runs beside the rear windscreen...There is a little black box which also runs the rear demister so be careful not to damage the other wires in the area!the Ant is the bigger think black one with the metal push clip like socket/connection! Might be worth wrapping some sticky foam (the stuff you use around door ways to stop drafts) as well... just incase when you move it, its rattles! (unlikley that itt would have come loose but).
timbos99 Member 300 Member For: 17y 10m 25d Gender: Male Location: QLD Posted 08/12/08 04:34 AM Posted 08/12/08 04:34 AM ill just drill a hole in my roof shall I??Haha sounds like someones on the rag.... His given you an answer and taken the time to help, you should be grateful not hateful. Congrats on the 20ft aerial
RHR BOOST Moderating Team 5,698 Member For: 23y 24d Gender: Male Location: Southern Highlands NSW Posted 11/12/08 03:45 AM Posted 11/12/08 03:45 AM Is there a fitting or plug in the rear of a sedan that can come loose. Mine was working and now its sh*tYou know you go alright when you can quote your own posts Had a bit of a look see today. Started in the boot and removed the pannel covering the amp. No loos wire no antena wire. Moved on to the pannel under the parcel shelf.. Again no wire.Pulled the parcel shelf off and no wire so I decided to pull the passenger side cover off (Near the seatbelt and its light grey in colour)Presto. Found a black box with what appears to be a thick black wire coming out of it.. Bit of a fiddle then fixed. I have no idea how this could have come loose.
Mr Man Mad Scientist Member 816 Member For: 21y 10m Gender: Male Location: Vic Posted 18/12/08 08:48 AM Posted 18/12/08 08:48 AM Found a black box with what appears to be a thick black wire coming out of it.. Bit of a fiddle then fixed. I have no idea how this could have come loose.where would one find this black box in a ute??
smicky Go Pies!!! Legacy Donating Member 2,852 Member For: 18y 7m 13d Gender: Male Location: Vic Somewhere - Sometimes NSW Posted 18/12/08 09:59 AM Posted 18/12/08 09:59 AM ute - not sure, I would guess the same spot behind the side rear windscreen as it is also the box for the rear demister!
tab Sucker Moderating Team 32,303 Member For: 22y 5m 5d Gender: Male Location: Brisbane Posted 18/12/08 10:33 AM Posted 18/12/08 10:33 AM Is that the antenna amp?
