marek Member 32 Member For: 15y 6m 9d Gender: Male Posted 06/11/08 11:13 AM Share Posted 06/11/08 11:13 AM that's tops Link to comment Share on other sites More sharing options...
qik1 Silver Donating Members 2,720 Member For: 15y 11m 29d Gender: Male Location: Loitering in SEQ Posted 06/11/08 04:54 PM Share Posted 06/11/08 04:54 PM bad news about the rain boys was waiting to see what you could get out of this nq animal. lucky theres a track not far from home I spose. do yas have any plans to bring it to the "cairns auto spectacular" comin up in the next couple of weekends? Link to comment Share on other sites More sharing options...
DUS12 Member 471 Member For: 16y 10m 5d Posted 07/11/08 03:26 AM Share Posted 07/11/08 03:26 AM yea I might bring it up and chuck it up on the dyno,and to dave saying he just pushed some buttons, my first tuner pushed some buttons and is threw a rod with 260rwkw, then my second tuner pushed some buttons and blew my second motor up with 350rwkw, since dave tuned is im nearly at 550rwkw and my car droped 2.2seconds off etI would rate him second to none,also to BRAD from ATOMIC, this is his 600kw bottom end that has done around 40000k now pumping close to 1000hp at the crank, compression test all cylinders are still within 3psi of eachother, it just completed a 3500km trim and has done a couple of hundred passeshands downs best xr6tengine money can buy, under 5 grand for this bottom end and it hasnt showed ANY signs of giving up, other engines for more than double the price wont do that Link to comment Share on other sites More sharing options...
senna_T Forged Member Lifetime Members 15,818 Member For: 17y 3m 3d Gender: Male Location: SW Sydney Posted 07/11/08 03:36 AM Share Posted 07/11/08 03:36 AM Good to hear a positive comment about the Atomic gear, I'm running the same kit in my car and its been bullet proof. The new version of this kit has new pistons with crown cooling and press fit gudgeon pins, os they are more reliable again. I'm about to build a motor for a Forum member using Brads gear, and trust me, when the car is finished it will get a work out!Good luck with your drag efforts Kent, sounds like a real monster! Link to comment Share on other sites More sharing options...
SCRIBR Yaris member Member 4,486 Member For: 17y 10m 19d Gender: Male Posted 24/01/09 04:10 AM Share Posted 24/01/09 04:10 AM has this been for a run yet? Link to comment Share on other sites More sharing options...
qik1 Silver Donating Members 2,720 Member For: 15y 11m 29d Gender: Male Location: Loitering in SEQ Posted 24/01/09 05:19 AM Share Posted 24/01/09 05:19 AM I think the cars still in bits. It's getting a full refresh with some serious bits going in. Link to comment Share on other sites More sharing options...
dmosconi Member 97 Member For: 16y 9m 8d Gender: Male Location: Perth WA Posted 24/01/09 05:34 AM Share Posted 24/01/09 05:34 AM Congrads on 500+, now to keep in a straight line! Link to comment Share on other sites More sharing options...
fordfreak XRT07 Member 378 Member For: 15y 10m 1d Gender: Male Location: glenwood Posted 29/01/09 12:16 AM Share Posted 29/01/09 12:16 AM absolutely insane!!! I like it!!! Link to comment Share on other sites More sharing options...
DUS12 Member 471 Member For: 16y 10m 5d Posted 26/02/09 11:53 PM Share Posted 26/02/09 11:53 PM yea bit of a up date for everyone, its now got a narrowed 9 inch with 15x10 convo pro's and 28x10.5 inch slicks, also got cal tracks,car is in getting a roll cage fitted 4 point weld in with 2 bars coming out through the back window being bolt in,also removed the motor to paint the engine bay, so I sent the motor back to atomic for a check up and some valve springs, that's where the story goes sideways ha ha, the motor was in excelent condition the bearings could have been put back in.but I thought while its apart maybe I should do a few little things to match my new number plates(100OHP)so hear goesheat treated, nitrited, and cross drilled crank750kw rods with crown cooling new mahle pisons with lower compression again, 8.0 to 1huge amounts of port work to the headbiggest valve springs from atomic298 and 302 degree cams ha haFG plenumsame 6 boost manifold and 1300hp turbo6 temp probes 1 in each runner of my exhaustbig stud girdle new bearings and timing chainthat's about it I thinkalso they c4 was looking brand new inside, HIGHLEY recomend als race glides so hopefully be back out very soon to let dave do his thing then we can go try rattle some cages with it Link to comment Share on other sites More sharing options...
Guest Guests Posted 27/02/09 12:04 AM Share Posted 27/02/09 12:04 AM Nice one mate Should be the quickest turbo ute in the country & first into the 9's soon! Link to comment Share on other sites More sharing options...
