January 2, 201016 yr #5651 quick question guys does anyone know how much or if it is worth it to get my car flashed back to standard so I can sell the flash tuner. As I am trading my xr6 in and they dont care for the tune
January 3, 201016 yr #5652 You'll be able to do it yourself mate, there would be an option on the tuner for stock tune...
January 3, 201016 yr #5653 2. With the key off, usethe ‘SELECT’ button tochoose the programyou wish to install intothe car (Factory, 1, 2 or3).F. on the flasher is for Factory.Just load that tune to return it to standard, which will work fine as long as you have no mods (usually even an exhaust system requires a tune).Keep in mind that each flasher unit is locked to a unique Vin number, so the flasher has to be returned to be re-programed. *The flash tuner can be changed over to a new vehicle, it must be cleared using software available from CAPA. This process can onlybe performed 5 times. Then it must go back to SCT / USA for a Reset.
January 3, 201016 yr #5654 ...and no good if you've changed injectors etc... What are you trading it on Wade?Good work Jme Did you use your winch?
January 3, 201016 yr #5656 that's what im chasing lowfutura, I know how to put the factory tune in but just not sure if it is worth reseting the flash box or just leave it on the carI traded it in on a MPS 3 as im looking for something different never had a small turbo car before always had skylines and xr6t's
January 3, 201016 yr #5660 hey guys just found my new personalised plates Edited January 3, 201016 yr by Ace
