Taxi 8 u Member 57 Member For: 15y 9m 27d Gender: Male Location: Where you want to be! Posted 24/07/08 12:35 PM Share Posted 24/07/08 12:35 PM If you are refering to the sub amp then it is mounted in the boot on the left side behind the trim panel, screwed to the back of the inner skin directly behind the wheel arch. that's the only amp the XRs have, full range speakers run directly from the head unit. hope that helps. Link to comment Share on other sites More sharing options...
quadie Donating Members 720 Member For: 18y 5m 23d Gender: Male Location: Muswellbrook,NSW Posted 25/07/08 06:54 AM Share Posted 25/07/08 06:54 AM perform my icc mod , and install ya stuff , just as good as a HU Link to comment Share on other sites More sharing options...
Slammer Member 81 Member For: 17y 17d Gender: Male Location: Motherland Posted 27/07/08 04:22 AM Share Posted 27/07/08 04:22 AM hay just a quick question. Does anyone know where I can get the handbreak signal wire for a dvd deck? The ICC is an 07 dual CC premo Link to comment Share on other sites More sharing options...
Taxi 8 u Member 57 Member For: 15y 9m 27d Gender: Male Location: Where you want to be! Posted 27/07/08 11:29 AM Share Posted 27/07/08 11:29 AM if you slide the rubber cover off the hand brake, exposing the pivot point you will see the switch with trigger wire, that's your point, but dont forget to cut the handbrake wire and put a 1amp diode in line, join your trigger wire to the switch side of the diode, or if you really want just ground that wire so you can watch DVDs while driving, its a bit hard at first but you get used to watching the road and that screen at the same time. not that I would do it or recommend it! Link to comment Share on other sites More sharing options...
F6_Charlie Donating Members 1,001 Member For: 19y 7m 27d Gender: Male Posted 27/07/08 11:37 AM Share Posted 27/07/08 11:37 AM Yeah you do get uses to it but I also wouldnt recommend it! Link to comment Share on other sites More sharing options...
Slammer Member 81 Member For: 17y 17d Gender: Male Location: Motherland Posted 27/07/08 12:28 PM Share Posted 27/07/08 12:28 PM Cool thnx im just wondering is there wire closer to the ICC, like off one of the plugs that I can splice into? The reason is I would pref not rn a cable all the way from the handbreak if I can. Also I will presume that the diode is so I dont blow my deck? Can I go without it though? Link to comment Share on other sites More sharing options...
Taxi 8 u Member 57 Member For: 15y 9m 27d Gender: Male Location: Where you want to be! Posted 27/07/08 12:43 PM Share Posted 27/07/08 12:43 PM you can go without the diode, its just that when the handbrake is off that circuit reverts back to a positive supply. no big drama. Link to comment Share on other sites More sharing options...
THRU5T Green Machine Donating Members 331 Member For: 17y 6m 24d Gender: Male Location: Melbourne Posted 05/08/08 05:12 AM Share Posted 05/08/08 05:12 AM Hey guys,Got the premium sound with Sub Woofer, but with Bass the sound vibrates the surround into a slight rattle? any remedy for this or could the sub woofer be gone? Link to comment Share on other sites More sharing options...
quadie Donating Members 720 Member For: 18y 5m 23d Gender: Male Location: Muswellbrook,NSW Posted 05/08/08 07:44 AM Share Posted 05/08/08 07:44 AM check to make sure u havent torn the rubber seal around the cone .. pull off the undertray from the boot by removing hte 3 white plastic clips around the boot light , and have a look up there give it a shake , may also be just a loose bolt or child restraint mount Link to comment Share on other sites More sharing options...
THRU5T Green Machine Donating Members 331 Member For: 17y 6m 24d Gender: Male Location: Melbourne Posted 05/08/08 08:53 AM Share Posted 05/08/08 08:53 AM check to make sure u havent torn the rubber seal around the cone .. pull off the undertray from the boot by removing hte 3 white plastic clips around the boot light , and have a look up there give it a shake , may also be just a loose bolt or child restraint mountThanks dude ill check it out!! Link to comment Share on other sites More sharing options...
