  • Member For: 19y 5m 5d
Posted
Ok pretty much the oil pressure light is going on and off alot some times staying on for a few minutes but mostly flashing on and off, When I check the dipstick it shows it at a good level no noticble oil leaks.
It started going this early this morning as I was on my way to work, I was thinking it may have been to do with how cold it was over night put some oil in this morning just to be on the safe side, drove the rest of the way to work with out any problems leaving work tonight its doing the same thing light going on and off and now it seems to be staying on for longer checked the oil again it still at the same level.
You can also feel the car stutter a little bit under acceleration
Any idea what may be causing or anything I should check or should I jsut take the car to ford or call the ravc if there is risk of something being damaged driving it.
I just had the valve springs replaces would this have any affect on any of the above.
Jim.
  • Replies 33
  • Legacy Donating Member
  • Member For: 21y 1m 13d
Posted
wouldnt think valve springts have anything to do with it.. Oil presure light is a indication of oilpressure loss... turbo oil screen could be clogged up, as the presure switch is mounted on the same fitting... oil pump could be failing ?? a number of things..
take it to ford is your best bet. and get them to check the turbo oil filter just near the oil filter where the presure sensor is..
danny.
  • Moar Powar Babeh
  • Member For: 21y 1d
Posted
What your describing sounds electrical. If it faults intermittently and flicker i doubt it would be the oil pump or a blocked oil passage as mechanic faults like a failed oil pump dot come and go they tend to stay once they happen.... :spoton:
  • Member For: 23y 9m
Posted
Could be a simple as your oil pressure sensor being faulty :spoton:
Posted
Part2 of this story.
Start the car up to go to work this morning check it out make sure no oil on the ground or anything oil light is not on and dipstick shows it as full.
I let it warm up for a few mins the set off to work I drive maybe 1km up the road the oil light comes back on within 1000 meters the car stops dead with the battery light on. I call the racv ( it seems I have ford roadside assist that I did not know about untill I got to ford this morning) I tell him whats been happing he hooks a booster battery up gets me to start it.
We hear some of noise coming from the engine he tells me to stop and says it could be a broken oil pump or a few other things engine is could be starting to seize up. Its been towed to ford and I will know sometime today or monday whats wrong with it :roflmbo:
its still in waranty so hope it will get sorted
Posted
If its oil pump drive, they will change the engine... bye bye nizpro valve springs...
Posted (edited)
your not helping :P I will see what happens I guess worst comes to worst I will just have to get it done again :roflmbo::spoton::censored: :censored: :censored: :censored: thank god its tax time soon
EDIT: maybe I will get the engine from the bf if they do that then I get better valve springs anyway :D
Edited by Jimbob
  • Member For: 20y 6m 4d
Posted
Do you think they will cover it all under the warrenty???
That is really bad news, there has been a few going boom @ the moment do you think its the weather??
Posted
I can say 99% chance u get the ba motor.. They are cructial to not mixing part numbers between different series.. Unless the replacement part number for both engines are the same part number... which wheni checked was not the case..
Posted
Keep in mind jimbobs car was completely stock minus the valve springs ..
