  • potty trained
  • Legacy Donating Member
  • Member For: 23y 5m 8d
Posted (edited)
APS have been busy ... check out Motor Mag :D
0-100 5.39
400m in 13.61 at 178.8km/h
I'll have some of that :thumbsup:
Daga Edit: Taken from another post by mickq.(Old post deleted same topic).
Some basic details:
Done by: Peter Luxton ABS
Unit installed: UniChip Engine Control Unit
Internal Engine changes: none
External changes via ECU: ignition advance curve, fuel injection map, turbo behaviour
External hardware changes: High flow Catalytic converter (this is optional)
Boost changes: Nothing below 3000rpm (to preserve the manual gearbox). At 3500 boost ups to 9PSI (from 6 standard). Tails off to 7PSI at 5500rpm (vs 5psi standard)
Igntion changes: Allows 8 or 9 degrees extra advance
Rolling dyno tests (all done on same dyno):
Standard XR6T:
claimed: 240kW (at the crank no doubt)
Rear wheel: 195kW
Standard XR8:
claimed: 260kW (at the crank no doubt)
Rear wheel: 180kW (!!)
Standard HSV GTS:
Claimed: 300kW
Rear wheel: 240kW
Modified XR6T (as above):
Claimed: 295kW
Rear wheel: 235kW
Damn impressive, and it only costs $1590 fitted!!! Extra $600-700 for the optional high flow cat.
Makes that $500 blow off valve someone installed seem a little rich, considering with the extra boost from this kit you also get a bigger pop-off sound as well as much more power!
0-100 times: 5.39sec
0-400m (1/4 mile): [email protected]
Now imagine changing the cams, the intercooler and air box, a high flow exhaust all the way to the back, bigger injectors, winding up the turbo to proper levels of boost, and whacking in the XR8's manual gearbox?! It would HAMMER. And then its time to do it all again with a bigger turbo!
Woohoo!
For the full drive report, go buy June edition of Motor Magazine.
Edited by Dagabond
  • Replies 52
  • The Noble Leader
  • Administrator
  • Member For: 23y 11m 22d
Posted
damn will have to go get the new Motor Mag tomorrow.. Peter Luxon is a great guy.. spoken to him on the phone quite a few times.. :thumbsup:
Guest StaggerLee
  • Guests
Posted
BLKXRT,
They're good figures. Is there any mention of the price for the APS modification? I assume it 280kw upgrade, but there's no mention of the price on the APS website.
  • The Noble Leader
  • Administrator
Posted
I would like to know a bit more about the mods!
Guest woosh
  • Guests
Posted
Just checked the newsagent this morning.. no Motor Mag :( is it out yet?
  • Formerly Turbo6
  • Member For: 23y 8m 25d
Posted
Very interesting (and exciting) article.
All they have done is a cat converter and the unichip. Peak boost is now 9si at 3500 rpm and trails down to around 7psi at 5500rpm.
Boost unaffected until 3000rpm for gearbox longevity.
I believe that this is still only available in Melbourne at this stage - you lucky b^&S**%!!!!!!!! :)
  • potty trained
Posted
about $2.5k will get you cats and chip ... 295fwkw ...... :nod:
for all intensive purposes ... that is a real cheap modification :D
as per Ford specs 240fwkw to 295fwkw for $2500
so that makes it about less than $45 per fwkw
now ... if we look at [holden] ... 260kw of the R8 to 300kw of the GTS say about $25000 in real terms for the extra 40kw ... about $625 per kw
now ... if we look at "FORD" the GT has 50kw more (manu's spec's) than the XRT and in real terms for $25000 more .... about $500 per kw
is anyone following this ??? :lol:
so one could save $20000 in real terms in the FORD market ...
a tremec t56 or tko or similar tranny upgrade will set you back about $7000-$8000 and the factory diff will take it ...
worst senario ... XRT say $45k plus chip etc $2.5k plus if tranny goes $8k ..
standing quarter in 13.6s for $55.5k .... that's alot of car ...... :nod:
I'm booked in !! B)
  • The Noble Leader
  • Administrator
Posted
now was that confusing or what :nod:
  • Member For: 23y 5m 17d
Posted
BLKXRT.... once again in english please :nod:
  • Formerly Turbo6
Posted
Pretty good reasoning........ :)
