  • Just because it is, doesn't mean it should be.....
  • Legacy Donating Member
  • Member For: 22y 14d
  • Gender: Female
Posted
take it back !!!
shazzy
  • Replies 21
  • Member For: 21y 27d
Posted
mine was a bit hard to change into 1 st  and  was mainly when stationary  2nd a few also , but it's come good , I took it to dealer with 2000 klms , and I didn't play up  , I thought I was clutch myself  its a 7/05 build . regards tony
<{POST_SNAPBACK}>
I have the same problem. :spoton: Interesting thing is mine is an 05/05 build. But now the clutch is starting to slip in 1st & 2nd.
It is going in next week, so we will see. :spoton:
  • Member For: 21y 8m 11d
Posted
Sams problem for me. Ford changed the clutch hydraulic fluid and charged me $40 for the pleasure . No better.
Posted
<{POST_SNAPBACK}>
And you paid??? :spoton::spoton::blink: nucken futts
vik...no way I would pay for a warranty issue,sounds like syncromesh to me???
  • Mal Wood Automotive
  • Member For: 23y 10m 19d
Posted
Will almost certainly be clutch drag, or failure to DIS engage. Will eventually wear out the first gear synchro. Ben.
  • Complete Bastard
  • Member For: 22y 9m 22d
Posted
T5 in mine and about 1 in 100 times, I have to give it a shove to get it into 1st gear. Clutch is not dragging as the symptoms did not change one bit when I had the clutch replaced with a Mal Woods unit (standard clutch did not cope with extra kw). MOFO looked at the car twice, could not reproduce the fault other than to say it is not a smooth gearbox and basically said 'live with it'. I just wanted it recorded on my service record as it is slowly getting worse. I don't know how smooth the T56 is however, the T5 is about as agricultural as a Russian built tractor. Even the Lada had a smoother gearbox!
  • Weird Member
  • Member For: 23y 7m 23d
Posted
My F6 has a similar problem of selecting 1st when stationary, like waiting at the lights.
I have found it occurs when you have had your foot on the clutch with the box in neutral for a long time (greater than 20 secs).
If you leave the car in neutral with your foot off the clutch then push the pedal wait a second then select first it is ok. :laughing:
Posted
<{POST_SNAPBACK}>
And you paid??? :laughing::sick::sick: nucken futts
<{POST_SNAPBACK}>
They told me it was caused by dirty fluid and that the fluid is not covered by warranty. Pissed me off but what can you do? Oh wait, I know, take it back and tell them it didn't @#$@#$ fix it.
It happens badly when cold but also at the lights. I've noticed that if I pop it out of gear and leave the clutch in that it seems to happen more often.
I'm wondering if it is clutch drag as WTB56 suggested.
  • Member For: 20y 10m 15d
Posted
Your problem sounds more serious - but I think most cars have this problem with first especially if you sit at the lights with your clutch in for a while.
The best solution I've come across over the years is to put the car in neutral, take the foot of the clutch, give it a couple of revs (2000pm is fine), then put foot back on clutch and put it first.
I have a feeling sometimes if everything isn't spinning when you try and engage a gear it can be trouble.
  • Colossal Member
  • Member For: 22y 1m 2d
Posted
Well that's true if the gears dont line up and they aren't spinning then they wont mesh properly. It's even worse on a bike if you have the clutch in too long, it wont select the next gear down. Even just letting your foot off the clutch a for a short period is enough to get the guts spinning again.
