  • - Track Bound EVO III -
  • Member For: 21y 9m 11d
Posted
Guys, needing more outlets in the ute.. I need to run PDA, Phone charger, GPS reciever and Radar detector, from ciggy adapters..
Anyone made something of a 'hub' up for the rear section of a ute ( behind seats ) ?? sedan even? how would I go about it??
Cheers..
  • Legacy Donating Member
  • Member For: 23y 7m 29d
Posted
It would be pretty easy to make one mate. Dick Smith or Jaycar will sell the ciggy adapters you need or get some sockets from a wrecker or super cheap even.
Make your box and mount you adapters together, wire them parallel and find a 12v feed to power them, you need to make sure that the circuit you choose has a big enough fuse to cope so you don't overload it.
The other option would be to take power straight from the battery to power your devices (Using an in line fuse) and then use a 12 volt relay to interupt the circuit and power the relay from and acc source so that the power to the sockets will only be there when the ignition is in the acc and save your battery going flat.
Cheers,
Dean
Posted
Very good..
What do u reckon of pinching/splicing power from the elec drivers seat?? Shouldn't be much of a drain on that, seeing as it never gets used..
  • Member For: 22y 7m 10d
Posted
True, but depending on the current you want, the cabling to the seats is pretty light.
  • Member For: 22y 7m 13d
Posted
Rather than using ciggy lighter sockets, have you considered hardwiring he most used items ?
The ciggy lighters are so ugly, you can bettr hide a hard wired solution.
  • Member For: 23y 5m 5d
Posted
How about you get one of those 10+ outlet powerboards, cut and rewire it to your ciggy lighter plug, and then velcro the 10 outlet powerboard across the length of your dash?
You sure use a fair bit of power!
Posted (edited)
<{POST_SNAPBACK}>
I have, yes.. But I want to be able to take the Radar Detector and GPS to other cars if needed, and hard wiring a phone charger?? meh..
Edited by XRT UTE
