  • Forum Superhero
  • Legacy Donating Member
  • Member For: 22y 10m 4d
Posted
so is 231.9 low or normal??
Low, but uyou need to factor in a number of things..
Manual or auto?
How old is it?
How many k's has it done?
Another thing is if you do not fit the right exhaust you will go backwards in power. there are a number of threads on research done on this topic, search find and read them, as the factory exhaust is quite good, not as simple as the old days with just changing bits................
  • Replies 41
  • Member For: 22y 2m 2d
Posted
ok its auto
early 2003
47000 kms
3 inch turbo back with high flow cat from di filippo!
  • Member For: 21y 6m 7d
Posted
So is a standard Manual more or less powerful than a standard Auto - given same age etc?
Posted
I know Autos soak up more power than a manual as a rule - but are the programs for the manual cars more powerful to start with?
  • In Your Face
  • Member For: 23y 6m 22d
Posted
Congrats mate once you get the Valve springs and injectors you'll be wanting more trust DRKXR6 :spoton:
  • Forum Superhero
Posted
ok its auto
early 2003
47000 kms
Hmmm, just the nature of the beast then, the one thing we know about the T's is the major variations in tolerances within the engine.
I suggest when you get the injectors and springs done you will see a solid increase upwards of 270rwkw.
The main measurement however is not against others but from the % gain you got from you base figure. What did theb car make stock, before the edit?
  • Forum Superhero
Posted
Same ecu programme, there is a setting for manual or auto. identicle as you said the autos soak up more power, however the Autos are quicker.
Posted
You say the Autos are quicker - is that as the manuals have clutch slip, or the auto is shifting quicker?
I would have thought the advantage of 6 gears over 4 would help?
  • Forum Superhero
Posted
There is alot of discussion on this topic, do a search. Autos are quicker, manuals have alot slower change and loose boost on changing. There is more to it but the ongoing results speak for themselves.
BTW I am a manual, so I know.
