Guest dabratman Guests Posted 29/12/04 10:00 PM Posted 29/12/04 10:00 PM hi from little nz. had reflash last week. felt worse , although had had no overboost issues. felt like it was running real lean. do they in fact disconnect the boost solenoid? they say it should be up on power. this car has big throttle body, cat back system etc and is slower than my mates stock one! hmmmmm. also put on turbosmart supersonic blow off valve, sounds mean but ford say u cant use them cause they upset the boost sensor. anyone know anything that may help?
KEN 24T Gandalf the Grey, Maiar of Manwë and Varda, Team HgAg/Sneaky Member 7,371 Member For: 23y 2m 17d Gender: Male Location: The Shire, Middle Earth Posted 29/12/04 10:29 PM Posted 29/12/04 10:29 PM hi from little nz. had reflash last week. felt worse , although had had no overboost issues. felt like it was running real lean. do they in fact disconnect the boost solenoid? they say it should be up on power. this car has big throttle body, cat back system etc and is slower than my mates stock one! hmmmmm. also put on turbosmart supersonic blow off valve, sounds mean but ford say u cant use them cause they upset the boost sensor. anyone know anything that may help?<{POST_SNAPBACK}>DaBratMan It would be remis of me to let your first (NEWBIE!! ) post go un-scathed, so in the spirit and traditional of welcoming new-comers ...Watchyawearn?
Guest dabratman Guests Posted 29/12/04 10:35 PM Posted 29/12/04 10:35 PM nice to meet ya! well the car wears 245/35 r19 pirelli's, and they stick like s**t to a blanket. highly recommended. as for me, well , never u mind
Guest TRACK Guests Posted 30/12/04 01:41 AM Posted 30/12/04 01:41 AM hi from little nz. had reflash last week. felt worse , although had had no overboost issues. felt like it was running real lean. do they in fact disconnect the boost solenoid? they say it should be up on power. this car has big throttle body, cat back system etc and is slower than my mates stock one! hmmmmm. also put on turbosmart supersonic blow off valve, sounds mean but ford say u cant use them cause they upset the boost sensor. anyone know anything that may help?<{POST_SNAPBACK}>Welcome Dabratman Not sure on the mechanics of it all, ie: solenoid bypassed or simply unplugged. But I thought it should have gone better, down low any way. I was led to believe they "disconnect" the solenoid that varys the boost from 0? up to max. Therefore, there should be times when the ECU only wants partial boost, but the engine is now getting full boost, and it should go better. that's how it was explained to me by the all knowledgable Ford guy anyway.Bottom line is, it used more fuel and I had to work like a Trojan just to keep pace with a normal Falcon/Dunnydore.My T wears 245/40r18 Yokahama AVS Sport. No chance of ripping these of the tarmac with this state of engine tune!!
Guest dabratman Guests Posted 30/12/04 01:49 AM Posted 30/12/04 01:49 AM can they therefore be 'unflashed' . I never had over boost issues anyways. only otehr option is piggy back phase II to sort the issues. why should we have to pay again to get the power we paid for in the first place.
profrat Member 126 Member For: 23y 2m 17d Location: Eastern Victoria Posted 30/12/04 02:27 AM Posted 30/12/04 02:27 AM My understanding of the 'by-pass' is that they 'disconnect' ecu control of the wastegate. As I understand it the car runs a base boost of about 5 psi. The ecu is able to increase this a couple of psi in the mid range. By disconnecting this control you only have the base 5psi max all the time. I belive they said they clamped a vacum hose. Could be wrong, and often are
shockwave Member 129 Member For: 22y 2m 26d Gender: Male Location: Melbourne Posted 30/12/04 06:14 AM Posted 30/12/04 06:14 AM My understanding of the 'by-pass' is that they 'disconnect' ecu control of the wastegate. As I understand it the car runs a base boost of about 5 psi. The ecu is able to increase this a couple of psi in the mid range. By disconnecting this control you only have the base 5psi max all the time. I belive they said they clamped a vacum hose. Could be wrong, and often are <{POST_SNAPBACK}>I went to my Ford dealer today and they gave me some spiel that they never by-pass or disconnect anything - they wouldn't flash my T with the new overboost fix program either. I just want to check it myself to make sure they're not bulldusting but don't know how to do it. Do I need to get under the car and look for a clamp or disconnected plug?All I can say is they made my T burn 2L/100km more after the 3K service. Anyone know a good Ford dealer (eastern suburbs) that will flash my T with the new program without booking in. I understand the "if it ain't broken don't fix it" mentality, but I see it as a software upgrade such as a Windows XP service pack. If it makes my T smoother and go better, I'm sold.
Miyagi fordxr5turbodotcom Member 892 Member For: 22y 11m 6d Gender: Male Location: Point Cook, Vic Posted 30/12/04 06:39 AM Posted 30/12/04 06:39 AM My understanding of the 'by-pass' is that they 'disconnect' ecu control of the wastegate. As I understand it the car runs a base boost of about 5 psi. The ecu is able to increase this a couple of psi in the mid range. By disconnecting this control you only have the base 5psi max all the time. I belive they said they clamped a vacum hose. Could be wrong, and often are <{POST_SNAPBACK}>I went to my Ford dealer today and they gave me some spiel that they never by-pass or disconnect anything - they wouldn't flash my T with the new overboost fix program either. I just want to check it myself to make sure they're not bulldusting but don't know how to do it. Do I need to get under the car and look for a clamp or disconnected plug?All I can say is they made my T burn 2L/100km more after the 3K service. Anyone know a good Ford dealer (eastern suburbs) that will flash my T with the new program without booking in. I understand the "if it ain't broken don't fix it" mentality, but I see it as a software upgrade such as a Windows XP service pack. If it makes my T smoother and go better, I'm sold.<{POST_SNAPBACK}>hrmm and Xp service packs have always been good ol relyable! I think the old addage, if it ain't broke... don't fix it applies here..
mk11tute Member 446 Member For: 21y 10m 23d Location: gold coast Posted 30/12/04 08:59 AM Posted 30/12/04 08:59 AM the lack of performance you guys speak of is it a flat spaot as such or is it just lazy, I have a mkii ute with 2900k's and to be honest nice car to drive etc but performance what performance my datsun 1600 would eat it alive. going in for first service tomorrow after reading what your guys have said not sure weather to mention this to ford or not?
Guest PSIXR6 Guests Posted 30/12/04 09:16 AM Posted 30/12/04 09:16 AM Hi All, I just had my T in for its 3000k inspection. When I booked it in, they told me it was on recall for a PMC change. I assume this was to flash the PMC with I new map. On the report sheet, It said it was PMC code PRGC 309. Is this the flash for the overboost problem, people talk about. I dont think my car has had overboost, but only thing I can coment on is that sometimes when I nailed the trottle, the car whould cut out around the 5000 to 5500. I it felt similar to hitting the Limiter Or was it Overboosting??? Well anyways I would like to report that the car now has a nice smooth idol, compared to before the service, the car would actually rock cause idle was so rough. ~allen
