  • Member For: 23y 3m 1d
Posted
Just recently paid $95.00 for a set (24) of BA GT valve springs from Ford, haven't had them fitted yet.
  • Replies 43
  • FORD FORD FORD
  • Legacy Donating Member
  • Member For: 23y 6m 21d
Posted
How are you getting them onto the T? They are too big without machining. Were they inlet of exhaust?
Scotty
  • Member For: 22y 4m 11d
Posted
I'm sure that Nizpro would have used XR8 ones if they were suitable, other wise why would you go top the trouble and expence of developing other valve springs.
My guess is if you check camshaft lift and rocker ratios you may will find that the XR6turbo and the V8 would be different. The coil windings would also be different. You would have to measure the gap between the coils when both springs are compressed at maximum lift. If the coils touch or bind it is not a good thing. Xr8 valve springs are also designed for N/A vehicles. Valve back pressure in turbo cars would be significantly higher I would think coil rebound would have to be different.
I might be wrong but it's my opnion anyway.
If the Techies can shoot me down go for it. :censored:
macka
Guest XR6Twish
  • Guests
Posted
From what I have read on the Nizpro website, their valve springs are designed to suit both stock and high lift cam applications. They don't require any head machining to fit and will suit extreme boost and horsepower applications.
Scotty, I reckon these may be good enough reasons for the extra $50?
  • Member For: 22y 2m 28d
Posted
My money is with Scotty!
He's on the mark as best bang for buck so far!
Also if he's using Xr8 springs & they're doing the job, then I'll be going down his path!
He has no monetry gain from telling you his experience!
Scotty keep it up, I'll always listen!!!! :3gears:
Russ
  • My new toy
  • Member For: 23y 5m 16d
Posted
I also have the xr8 springs and have no problems at all.
Ian
  • My new toy
Posted
Also the xr8 springs are made of thicker springs but have less coils so they will not bind when full compressed.
Ian
Posted
Russ
:blink: Talk about pen*s envy :ermm::ermm:
vik
  • FORD FORD FORD
Posted
Other wise why would you go top the trouble and expence of developing other valve springs.
They are 100 thou from coil bind, they show 52psi when the valve is shut & 160 when it is open, as opposed to the standard springs that show 60 shut & 125ish opened. These figures I compiled whilst standing next to the biggest distributor of Valve Springs in Australia.
The T springs are the same as the N/A Barra 182 springs which makes the aspirated v forced induction question seemingly irrelevant.
If you want to run bigger camshafts in the future no spring you fit now will suit future applictaions, which I'd think is plainly obvious, unless you are going to shim it, which isn't a very clever idea. You'll fit bigger springs & machine the heads to fit them when you've your engine apart for the power up. Like BCL has done.
I'd say Nizpro developed their own spring overseas purely for a cost versus supply issue, they'd of had to produce a huge quantity for a one of spring & would rather do that than go back & forth to FoMoCo constantly.
The Xr8 valve springs work, Goldie noticed more boost when he fitted them to his beast & he wasn't having Valve flutter at all.
Not intending to put anyone down or offend, but these stats are factual.
Scotty
  • Member For: 22y 8m 23d
Posted
Youre both right.
It was a PITA getting a supply of springs from Ford & the springs we have made allow for higher lift camshafts & more boost that the OEM ones.
