August 30, 200422 yr #11 wasn't one of the companies using of all things a type of Expensive Daewoo spring to fix the valve spring problem?What was the result? , did it work?, or just a load of crap?
August 30, 200422 yr #12 XR8 ones are more than adequeteScottyAt $286 for the Nizpro valve springs, why would you bother with XR8 ones? Edited August 30, 200422 yr by XR6Twish
August 31, 200422 yr #13 XR8 ones are more than adequeteScottyAt $286 for the Nizpro valve springs, why would you bother with XR8 ones? Surely that's not 280 fitted.....what springs do Nizpro use???
August 31, 200422 yr #14 wasn't one of the companies using of all things a type of Expensive Daewoo spring to fix the valve spring problem?What was the result? , did it work?, or just a load of crap?Yes, but the problem was the engines then began guzzling copious quantities of oil ...... :sick:
August 31, 200422 yr #15 XR8 ones are more than adequeteScottyAt $286 for the Nizpro valve springs, why would you bother with XR8 ones? Surely that's not 280 fitted.....what springs do Nizpro use??? They are made to our specs by an OEM manufacturer but they arent an OEM spring. Oh, & no that's not fitted. Edited August 31, 200422 yr by edo
August 31, 200422 yr #16 Beats the hell out of the price I got from a Brisbane APS installer, which was $1,000.00 Installed!
August 31, 200422 yr #17 XR8 ones are more than adequeteScottyAt $286 for the Nizpro valve springs, why would you bother with XR8 ones? Tell me in what way are they better for me to pay $50 odd more.Scotty
August 31, 200422 yr #19 I've got a quote for a set of XR8 valve springs for $192. Sutty,I hope that was for 24 & not 18, sorry to suggest it but I gotta ask.Scotty
