  • Member For: 10y 5m 6d
  • Gender: Not Telling
Got the dyno up and running in the shed today, it's been nearly exactly a year, $110k and a whole bunch of work but it's there.
There's still plenty to do but the hard part is done.
I did some tuning on the Caprice, my neighbour was in his back yard and he reckoned it wasn't that loud, even with full ramp runs. He said he couldn't even hear it in his house so I reckon I'm golden.
So yerp there's that, I'll post another pic tomorrow, didn't look much different though lol.
Yep, big fence, insulated shed plus their house is stone so it all helps. If the direct neighbour isn't bothered then I doubt anyone else will be.
Spent the past couple of days tuning the Caprice on the dyno. I fitted some knock ears, ran a wideband into the datalog, as well as having the dyno wideband hooked up, then got to learning.
I switched the knock sensors on the car off and did some runs. There was no knock even though the car was previously pulling timing with the sensors switched on. I added timing and pulled timing out to see where it wanted to be. Interestingly enough it wasn't knock limited so there wouldn't be many gains by using E85 in this setup. I adjusted the WOT fuel up and down to see where it was happiest and turns out it wants to be very lean down low at WOT but quite rich up top, at least by NA standards.
I have some exhaust extraction stuff so I half assedly hooked it up. It helped out a fair bit and I didn't die of CO poisoning.
I really should fix the territory, that will be a whole lot of fun tuning that.
  • Member For: 6y 7m 1d
What motor is in the caprice? Do you make your living being a back yard mechanic? Are you busy on customers cars usually and do you advertise or is it just word of mouth, go to puffwagons garage? Hes a legend.
  • 2 weeks later...
