  • New Member
  • Member For: 4y 6m
Posted
Hey guys
I've got a bf f6 typhoon and have a bad shake in the steering but it happens intermittently. I have had every single bush in the front end done and still get it. Took the car back to pedders to try and show them the issue and of course it didn't happen over the 20 minutes in the car with the mechanic. Drove the car home from pedders and it started happening again. I pulled over, came to a stop, took off, drove for another 15 minutes with out it happening. Has anyone had this happen to them?
  • New Member
  • Member For: 4y 6m
Posted
Felt good after wheel alignment, 20kms  later the wobble is back and it intensifies when I touch the brake pedal. I have brand new brakes on the front aswell
  • Member For: 8y 21d
Posted
Hmmmm take rotors off and make sure they rotor and hub surface is clean of debris? This can cause a wobble.
Also could be warped rotors.
  • New Member
  • Member For: 4y 6m
Posted
Rotors and pads are brand new hey...but jacking it up, taking wheels off and havin a look to see what I can find
  • New Member
  • Member For: 4y 6m
Posted
Found front r/h wheel bearing had play, changed that and its all sweet now drives like a dream!
