  • Member For: 10y 11m 27d
Posted
Have you checked to make sure the engine mounts are done up tight? What about the exhaust mounts? Have you checked/replaced those?
  • Dropping a turd
  • Legacy Donating Member
  • Member For: 18y 11m 8d
Posted
What about the 3rd front bush and transfer case bush.  How are the Tailshaft bearing. ?
  • New Member
  • Member For: 6y 2m 3d
Posted
Engine mounts brand new and done up tight, tail shaft bearing not very old and looks ok. not sure if exhaust mounts would cause a vibration.The vibration feels like its now up front.
Thanks for your comments, everything helps.
Regards AndyF6X
  • Member For: 12y 5m 17d
Posted (edited)
Have you changed ALL THREE diff bushes up front. People often only do the two bushes on the passenger side and not the "3rd diff bush" on the drivers side. Many have said that this has been the cause of the vibrations you are describing under load.
pic of "3rd diff bush"
Edited by burkey05
uploading pic
  • New Member
Posted
Hi Burkey05
Not sure what I'am looking at in your picture. Is your 3rd bush your talking about  the same as the rear engine mount/gearbox mount part number A6016 as I cant see any other bushes on the drivers side.
Thanks AndyF6X
  • Dropping a turd
  • Dropping a turd
Posted
Yes 2 on passenger side and 1 on drivers side. How many Ks the car done. ??
  • New Member
Posted
Hi Arronm
Ok found it. The 2 on the passenger side have just been done but I didn't know about the one on the drivers side but had a good look and it looks in good shape, it also looks more like  a locating bush mounted vertically rather than horizontally. Can this bush be removed and replaced from the bottom?
The second part you mentioned ,rear gearbox mount I have ordered and will do the two together.
So far I have replaced 3 X rear diff bushes. 2 X front left diff bushes. 2 X engine mounts.
If the front right diff bush and rear gearbox mount doesn't fix it I only have drive shafts left.
Thanks AndyF6X
