AndyF6X New Member 17 Member For: 4y 9m 6d Posted 31/07/20 12:36 PM Share Posted 31/07/20 12:36 PM Hi All I have just bought a FPV F6X unfortunately it has a vibration while in high gears and under load. I have changed the rear and front diff bushes and balanced the tail shaft on and off the vehicle and I'am still getting a vibration. the only thing left is engine and gear box mounts. Ford want nearly $1200 for a pair of engine mounts does anybody know if you can get after market mounts. Thanks Link to comment https://www.fordxr6turbo.com/forum/topic/95863-fpv-f6x-engine-mounts/ Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,485 Member For: 17y 27d Gender: Male Location: Melbourne Posted 31/07/20 01:08 PM Share Posted 31/07/20 01:08 PM it could also be your front balljoints. Link to comment https://www.fordxr6turbo.com/forum/topic/95863-fpv-f6x-engine-mounts/#findComment-1697284 Share on other sites More sharing options...
AndyF6X New Member 17 Member For: 4y 9m 6d Posted 31/07/20 10:11 PM Author Share Posted 31/07/20 10:11 PM Hi k31th Thanks for your reply. Ball joints have also been done. Does anybody know if you can use the normal Turbo Territory engine mounts. I would assume the F6X mounts are physically the same just a stiffer compound to put up with the extra torque. AndyF6X Link to comment https://www.fordxr6turbo.com/forum/topic/95863-fpv-f6x-engine-mounts/#findComment-1697285 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,485 Member For: 17y 27d Gender: Male Location: Melbourne Posted 01/08/20 12:03 AM Share Posted 01/08/20 12:03 AM they are the same mounts. Link to comment https://www.fordxr6turbo.com/forum/topic/95863-fpv-f6x-engine-mounts/#findComment-1697287 Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 6m 10d Gender: Male Location: Perth Posted 01/08/20 12:19 AM Share Posted 01/08/20 12:19 AM (edited) 11 hours ago, AndyF6X said: Hi All I have just bought a FPV F6X unfortunately it has a vibration while in high gears and under load. I have changed the rear and front diff bushes and balanced the tail shaft on and off the vehicle and I'am still getting a vibration. the only thing left is engine and gear box mounts. Ford want nearly $1200 for a pair of engine mounts does anybody know if you can get after market mounts. Thanks Did you replace all 3 front bushes? Transfer case mount ? rear gearbox mount ? I use these engine mounts in my turbo. https://www.supercheapauto.com.au/search?q=territory engine mounts&lang=en_AU&vid=Bd0kuvFDTV4oq46EEkk29w%3D%3D Only difference for F6X is blue intercooler cover, bigger brakes, bigger exhaust tips. And better tune,. Edited 01/08/20 12:35 AM by arronm Link to comment https://www.fordxr6turbo.com/forum/topic/95863-fpv-f6x-engine-mounts/#findComment-1697290 Share on other sites More sharing options...
AndyF6X New Member 17 Member For: 4y 9m 6d Posted 01/08/20 01:54 AM Author Share Posted 01/08/20 01:54 AM Hi Arronm Replaced 3 rear diff bushes and all front bushes except rear gearbox mount. If I replace rear gearbox mount and engine mounts hopefully vibration will go. Every job on these are difficult to get to. Thanks AndyF6X Link to comment https://www.fordxr6turbo.com/forum/topic/95863-fpv-f6x-engine-mounts/#findComment-1697297 Share on other sites More sharing options...
AndyF6X New Member 17 Member For: 4y 9m 6d Posted 02/08/20 09:38 AM Author Share Posted 02/08/20 09:38 AM I will be very happy for a long time keep after I have sorted out some of the gremlins. Another one found today. Vehicle starts and runs smoothly but after sitting in traffic for a few minutes the engine starts to run rough and try's to stall. The head was rebuilt 2 years ago so the inlet and exhaust manifold gaskets were replaced. Any Ideas ??? Thanks AndyF6X Link to comment https://www.fordxr6turbo.com/forum/topic/95863-fpv-f6x-engine-mounts/#findComment-1697362 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,485 Member For: 17y 27d Gender: Male Location: Melbourne Posted 02/08/20 09:41 AM Share Posted 02/08/20 09:41 AM sounds like a dirty intake Link to comment https://www.fordxr6turbo.com/forum/topic/95863-fpv-f6x-engine-mounts/#findComment-1697363 Share on other sites More sharing options...
AndyF6X New Member 17 Member For: 4y 9m 6d Posted 02/08/20 11:49 AM Author Share Posted 02/08/20 11:49 AM Hi k31th Thanks. Will have a look tomorrow. Link to comment https://www.fordxr6turbo.com/forum/topic/95863-fpv-f6x-engine-mounts/#findComment-1697374 Share on other sites More sharing options...
AndyF6X New Member 17 Member For: 4y 9m 6d Posted 11/08/20 11:29 AM Author Share Posted 11/08/20 11:29 AM Hi All Replaced engine mounts and rear gearbox mount today. Vibration has reduced but still there under load. A few people have said that these territories also have troubles with the drive shafts so that's my next project. The vibration has changed from the whole vehicle shaking to a smaller vibration which feels like its just coming from under the drivers feet. Is there anything else inside the diffs or transfer case that could cause this. After the drive shafts are done that's the whole drive train replaced. Thanks AndyF6X Link to comment https://www.fordxr6turbo.com/forum/topic/95863-fpv-f6x-engine-mounts/#findComment-1697661 Share on other sites More sharing options...
