ERICtheBERIC Member 105 Member For: 10y 10m 8d Gender: Male Location: Perth Posted 15/05/20 06:20 AM Share Posted 15/05/20 06:20 AM Gday guys, just after a bit of advice again if I could im getting together some parts for hopefully a ~400 rwkw fg turbo motor build for my BA Ive recently bought a second hand plazmaman surge tank with twin bosch 044, which I am planning on using just the one pump on and ive got another 044 in the tank in an aftermarket cradle with larger swirl pod etc I bought ages ago really wanting to use the stock FG turbo fuel rail to save some money, Will the stock fuel pressure reg suffice or should I go one of those GFB drop in FPR's? Link to comment https://www.fordxr6turbo.com/forum/topic/95697-what-fpr-to-run/ Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 17y 1m 12d Gender: Male Location: Adelaide Posted 15/05/20 09:51 PM Share Posted 15/05/20 09:51 PM Stock one won’t work correctly so use a GFB drop in mate 2 Link to comment https://www.fordxr6turbo.com/forum/topic/95697-what-fpr-to-run/#findComment-1694772 Share on other sites More sharing options...
NA_TURBO Member 532 Member For: 9y 9m 4d Gender: Male Location: Mildura Posted 16/05/20 01:05 AM Share Posted 16/05/20 01:05 AM Set up your fuel system properly, you'll probably be safer running 2 bosch 044s on the surge tank if you're going for 400rwkw. Otherwise you'll be changing/adding pumps on the dyno Link to comment https://www.fordxr6turbo.com/forum/topic/95697-what-fpr-to-run/#findComment-1694781 Share on other sites More sharing options...
gaz097 Bronze Donating Members 1,752 Member For: 13y 11m 22d Posted 16/05/20 01:10 AM Share Posted 16/05/20 01:10 AM Only if E85. 400 on 98 is quite achievable Link to comment https://www.fordxr6turbo.com/forum/topic/95697-what-fpr-to-run/#findComment-1694782 Share on other sites More sharing options...
ERICtheBERIC Member 105 Member For: 10y 10m 8d Gender: Male Location: Perth Posted 17/05/20 03:02 AM Author Share Posted 17/05/20 03:02 AM cheers guys Link to comment https://www.fordxr6turbo.com/forum/topic/95697-what-fpr-to-run/#findComment-1694822 Share on other sites More sharing options...
