violetpop Silver Donating Members 436 Member For: 4y 4m 20d Posted 10/08/22 09:13 AM Author Share Posted 10/08/22 09:13 AM Picked up a gas engine with plans for a low buck rebuild and attempt to re use as many of my add ons as I can. So far I've got an elite gasket kit, dominator head gasket, Hastings rings and acl bearings, genuine rod studs. This is being done late at night a few days a week because that's the only time I have available.It looked like the gassy had run on petrol and didn't present clean like they normally do. All good, more cleaning. Link to comment Share on other sites More sharing options...
violetpop Silver Donating Members 436 Member For: 4y 4m 20d Posted 10/08/22 09:21 AM Author Share Posted 10/08/22 09:21 AM So far I've gapped rings and checked main bearing clearance. Rings top and middle gapped at 23 thou and main clearance came in well past the service limit. After watching the average garage video he mentioned he spoke to atomic who said its ok, we will find out.At this point I'm doing everything as best as I can but don't really give a sh*t about what happens when it goes in the car and fires up.The acl bearings look trash, is this normal? Link to comment Share on other sites More sharing options...
gaz097 Bronze Donating Members 1,751 Member For: 12y 9m 8d Posted 10/08/22 09:32 PM Share Posted 10/08/22 09:32 PM Is it a single layer head gasket or multi? If your not machining anything go a single layer. Bearings as in puffs thread can be fairly loose without issue. I believe what ford calls worn out is close to atomic new spec. You can buy thou under size Bearings as well. Plastigauge has its place. Measuring the journal is better. Are them Bearings new? 1 Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,135 Member For: 9y 2m 30d Gender: Male Location: South Australia Posted 11/08/22 12:02 AM Share Posted 11/08/22 12:02 AM Yeah bearing look all kinds of funky when they're new, nothing to worry about. I am running an inconel spring and adjustable relief in my oil pump that will bump pressure up to 110 - 160psi, which is why I decided to go with hx bearings. I ran my last build with 2 thou on the mains, which is where yours is now, and the bearings were fine with the power level I was running. To measure the crank properly you should measure it in 6 places per journal to see the size of it, how much taper it has and how round or oval it is. You need an outside micrometer to do this and they are surprisingly cheap. I paid $169 for my set, although they have jacked the price up a bit now. https://www.totaltools.com.au/46265-tti-4-piece-micrometer-set-l501102 I know cranks look worse in photos but it looks like yours could do with a polish. You want that mofo shining! 1 Link to comment Share on other sites More sharing options...
violetpop Silver Donating Members 436 Member For: 4y 4m 20d Posted 11/08/22 12:36 AM Author Share Posted 11/08/22 12:36 AM You rekon I should fit a high pressure spring like the plazman one? That kits looks nice I was looking for something like that. Hard pressed for time is the issue and this really is turning out to be a half slap job.Any tips on diy polishing the crank? I've got half a tube of autosol haha Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,135 Member For: 9y 2m 30d Gender: Male Location: South Australia Posted 11/08/22 01:09 AM Share Posted 11/08/22 01:09 AM Yeah man more oil pressure ain't a bad thing when you're flogging the hell out of your car. You can get a crank polished for about $100 at an engine shop and they can measure it for you too. They remove any scratches and roughness from it so the bearings live a long and happy life. A side effect of it being smooth is being shiny, no point just shining it up lol. Now is the time to ensure the crank is perfect, or at least good enough to run, and it doesn't take much time or money to do it. Drop it off today and you might have it back tomorrow. Link to comment Share on other sites More sharing options...
violetpop Silver Donating Members 436 Member For: 4y 4m 20d Posted 11/08/22 03:47 AM Author Share Posted 11/08/22 03:47 AM that's not too bad for the crank I just might do it. Ordered the spring so that's on the way. Link to comment Share on other sites More sharing options...
violetpop Silver Donating Members 436 Member For: 4y 4m 20d Posted 22/08/22 11:55 AM Author Share Posted 22/08/22 11:55 AM Engine is ready to go in the car now. Re used my valve springs, head studs and oil pump. New guides and tensioner, head gasket. Drilled and tapped a spare na sump for the oil return. 5 Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,314 Member For: 16y 19d Gender: Male Location: Melbourne Posted 22/08/22 11:56 AM Share Posted 22/08/22 11:56 AM Looking clean 1 Link to comment Share on other sites More sharing options...
violetpop Silver Donating Members 436 Member For: 4y 4m 20d Posted 01/10/22 08:50 PM Author Share Posted 01/10/22 08:50 PM Engine has been back in the car for a few weeks now, transmission arrived and quickly fitted into the car. Few things to tidy up and first start should be a few days away. Fingers crossed for good oil pressure and no knocks bangs or rattles haha I've had to resort to riding my mt09 to get my thrills. Major first world problems. 1 Link to comment Share on other sites More sharing options...
