  • New Member
  • Member For: 7y 8m 9d
Posted
Hey guys, new here and finding trouble elsewhere regarding my problem ..
have an FG with the ZF 6 Spd auto
recently noticed a click sound when into reverse on start up and the occasional click when it changes gear or backing off the throttle .. it’s not coming from the engine bay that I am sure of, only when gear changes happen.. the sound is not a clunk or bang , just a gentle click sound .. apart from that the auto works great, any ideas as I’m worried the auto is gonna die ..
cheers klay
  • Legacy Donating Member
  • Member For: 11y 7m 28d
  • Gender: Not Telling
Posted
I would start by checking that the rear wheel nuts are tight then I'd see if the noise was coming from the cv shafts.
Also a d shackle hanging of the tow bar will swing around and make clicking noises.
Might not be that, but it's the first things I'd check.
  • New Member
Posted
Lol Naah, loose wheel nuts know that sound and feel, & “CV shafts” think not brother ?.. the click is coming from the auto.. not the engine or rear of the car .. and I removed the dangly ballsacks from the towbar ages ago ???
Posted
6 minutes ago, Klaymann888 said:
CV shafts
I meant cv joints bro. They click. But yer, good luck with it.
  • Member For: 8y 2m 19d
Posted
I had a loose bolt on the flex coupling between the box and drive shaft.
Sounded very similar to what you are describing.
Posted
Just a click,
Started softly occasionally then pretty much constant, but only below 60kph.
  • Member For: 11y 5m 4d
Posted
Puff your rods say no....
Okay, get someone to put in reverse while you lay next to the car on the ground. Might help you narrow down the exact location.
  • New Member
Posted (edited)
Bingo.. that’s exactly what mine does .. Cheers will check that out
“Just a click,
Started softly occasionally then pretty much constant, but only below 60kph.”
Edited by Klaymann888
Posted
That's almost exactly how you would check for cv's and wheel nuts. Reverse and drive a bunch times. Everything I suggested makes clicking sounds under the conditions of the original post and all of them can be checked in the space of a few minutes with the reverse to drive method.
Sure it could also be the flex plate but there are easier things to rule out first.
But hey wtf would I know right?!
