Barracitric New Member 5 Member For: 5y 8m 8d Posted 19/08/18 03:01 AM Share Posted 19/08/18 03:01 AM Hi guys, I am a proud owner of a bog stock ba Xr6turbo, absolutely love it and now am wanting to maximise the amount of power from the standard parts on my car. I recently added a manual boost controller and gained a few extra psi’s and absolutely love it. I think it maxes out to about 10psi and then it just cuts out. So I have since dialled it back to about 8psi and that seems to be the max I can get without encountering the cutout issue. So my question to you guys out there that have been through this, what could be stopping my car from making more power? I understand ppl have recommended edit/capa which I will do later down the track but really all I’m wanting is a few psi’s at this point and something is currently restricting my car from making those few psi’s? any my idea how much power the standard spark plugs are good for? Cheers Any help would greatly be appreciated. Thanks.? Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,133 Member For: 9y 2m 29d Gender: Male Location: South Australia Posted 19/08/18 03:10 AM Share Posted 19/08/18 03:10 AM It's hitting the overboost threshhold. Unless you are tuning it yourself you will want to grab some injectors, a fuel pump and a tune for the best bang for buck. That'll be somewhere around the $1500 to $2000 mark supplied, fitted and tuned. Also, stock plugs have made north of 800hp with adjusted gaps. Plugs are plugs for the most part. Link to comment Share on other sites More sharing options...
Barracitric New Member 5 Member For: 5y 8m 8d Posted 19/08/18 03:16 AM Author Share Posted 19/08/18 03:16 AM (edited) Thanks for the reply mate. I understand u can make heaps more power by adjusting the factory plugs however any idea how much kw these standard plugs can make without gapping then? Thanks Edited 19/08/18 03:17 AM by Barracitric Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 16y 6m Gender: Male Location: Perth Posted 19/08/18 03:28 AM Share Posted 19/08/18 03:28 AM Its not power its boost. Stock gaps are BA 1.1mm and BF 0.9mm. Once you go past about 10 -12psi best drop to 0.7 - 0.8mm. You can regap STD plugs but best just buy these. https://www.ebay.com.au/p/Ford-BAII-6cyl-LPG-Genuine-Service-Kit-From-10-2004/1736940827?iid=290628022377&_trkparms=aid%3D222007%26algo%3DSIM.MBE%26ao%3D2%26asc%3D20151029142714%26meid%3D9c91391ada734d64923733c6962fcaff%26pid%3D100005%26rk%3D2%26rkt%3D5%26sd%3D230649247956%26itm%3D290628022377&_trksid=p2047675.c100005.m1851 Link to comment Share on other sites More sharing options...
El Andrew Gold Donating Members 2,019 Member For: 9y 5d Gender: Male Location: Canberra ACT Posted 19/08/18 04:12 AM Share Posted 19/08/18 04:12 AM Lol Arron you must have that link as a keyboard shortcut by now!I've got a set ready to go in Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 16y 6m Gender: Male Location: Perth Posted 19/08/18 04:16 AM Share Posted 19/08/18 04:16 AM (edited) Dude, its cheap great plugs. Why pay $25 a plug. Just trying to save people money, as you know... PS- newbies always want more power..... Edited 19/08/18 04:18 AM by arronm Link to comment Share on other sites More sharing options...
El Andrew Gold Donating Members 2,019 Member For: 9y 5d Gender: Male Location: Canberra ACT Posted 19/08/18 04:18 AM Share Posted 19/08/18 04:18 AM Absolutely! Link to comment Share on other sites More sharing options...
bossmang FREAKY Donating Members 12,403 Member For: 14y 4m 2d Gender: Male Location: Melbourne Posted 19/08/18 04:42 AM Share Posted 19/08/18 04:42 AM I stopped reading and caring when I read, manual boost controller and capa 1 Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,133 Member For: 9y 2m 29d Gender: Male Location: South Australia Posted 19/08/18 05:05 AM Share Posted 19/08/18 05:05 AM 1 hour ago, Barracitric said: how much kw these standard plugs can make without gapping then? In a stock car not a lot. They start to blow out around the 10psi mark give or take. You could use a spark booster to prevent that but that isn't the best/cheapest way to modify your car from stock. You wont make power from gapping your plugs as a general rule, you'll just prevent the intake charge from being blown out. I've seen a plug change make a 50hp difference but...you know...variables. Link to comment Share on other sites More sharing options...
Barracitric New Member 5 Member For: 5y 8m 8d Posted 19/08/18 05:40 AM Author Share Posted 19/08/18 05:40 AM Hi guys I just finished installing bkr6eix spark plugs gapped at .80mm and that made no difference.... Link to comment Share on other sites More sharing options...
