  • Dropping a turd
  • Member For: 17y 7m 20d
True.  But leave it to long and it may require engine out
good excuse to build one.  I am considering short stroke engine.
  • Member For: 11y 8m 17d
Wtf the point of destroking it when you don't even rev it past 7500 as it is now?? The stoke stroke is fine at 7500 everyday and is fine to rev to 8000rpm on the limiter doing powerskids don't think you'll ever go that far...
  • Member For: 20y 8m 23d
Yes I could get away with just doing the head gasket but I would want to re seat the valves, do some porting, valve springs, and head studs if the heads coming off.
At that point I might as well build the motor.
I think you need to remove the engine just to do head studs, not sure if you can get the head on with the motor in the car.
Edited by Typhoon
  • Member For: 10y 4m 17d
  • Gender: Not Telling
Not quite man. If that's the plan then sure that's the time to do it. There is a big difference between a whole engine recon and a head recon. I always do the most of the stuff you mentioned when the head is off. Hand porting is a pita aka time consuming but if you can be bothered then go for it.
As eff xr6t said you can definitely fit the head onto the block with it in the car.
  • Member For: 8y 1m 12d
On 5/9/2017 at 9:32 AM, skidxr6t said:
sell it while it still rips skids  :P
that's what I did with my old BF. still ripped skids, not my fault when everything blows up a few weeks later.
this just happened to me. bought a bf mk 2 ute and it blew up in 300 kms time.
  • 1 month later...
**Update**
The head is not leaking coolant. Its just oil. This motor leaks heaps of oil, main seals head gasket power steering pump etc.
I have had the car re-tuned. 440kws @ the hubs 17psi. (ZF BFII full Nizpro stage 2 plus kit + GEN2 GTX3582r + surge + E85)
My issues were tune related.
