Elturbo New Member 19 Member For: 7y 10m 22d Gender: Male Location: Melbourne Posted 01/02/17 05:30 AM Share Posted 01/02/17 05:30 AM Hi guys, recently started having a problem with my 2006 bf turbo zf. car is fine under normal driving, as soon as you give her a bit of gas the abs light and hand brake light both flash on then a couple of seconds later the speedo stops working and "D" starts flashing on dash (but does not go into limp home mode still drives normal just no speedo). Turn the car off and on and the speedo works again. Also just replaced alternator started happening around the same time. any ideas?? Abs sensors? Bad battery? Mechanic run a scan on the car but he couldnt pin point the problem... really annoying issue cant drive it hard at all without this happening any ideas much appreciated. Link to comment Share on other sites More sharing options...
BAXRTUTE Gold Donating Members 2,639 Member For: 8y 9d Posted 01/02/17 05:54 AM Share Posted 01/02/17 05:54 AM Loose fuse? Loose wiring? Its electrical by the sound of it. Know a auto electrician? Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,133 Member For: 9y 2m 29d Gender: Male Location: South Australia Posted 01/02/17 06:01 AM Share Posted 01/02/17 06:01 AM (edited) I read something lately about an undercharged battery showing these symptoms. I didn't charge my new odyssey battery when I got it a few weeks ago and although it started the car, when I gave it some stick the speedo went to zero but the car drove normally. I pulled over, restarted it and haven't had a problem since. Edited 01/02/17 06:02 AM by Puffwagon a word Link to comment Share on other sites More sharing options...
skidxr6t skids Donating Members 2,754 Member For: 11y 3m 30d Gender: Not Telling Posted 01/02/17 06:02 AM Share Posted 01/02/17 06:02 AM (edited) coilz got crackz in them. and/or dirty battery terminals so the other suggestions are valid about the battery. Edited 01/02/17 06:02 AM by skidxr6t Link to comment Share on other sites More sharing options...
Elturbo New Member 19 Member For: 7y 10m 22d Gender: Male Location: Melbourne Posted 02/02/17 05:43 AM Author Share Posted 02/02/17 05:43 AM Also forgot to add that I have the problem with the ignition barrel spring, the key doesnt spring back when you start the car and so times does odd things like radio wont work ect... not sure if this could have anything to do with it. anyways ill throw my brothers battery in tonight and see of that fixes it. thanks guys Link to comment Share on other sites More sharing options...
ROB83R Member 1,632 Member For: 7y 11m 8d Gender: Not Telling Location: Radioactive wasteland Posted 02/02/17 08:45 AM Share Posted 02/02/17 08:45 AM It would stop everything working that turns off while cranking. Make sure you sit it back where it should be and see how you go. Link to comment Share on other sites More sharing options...
JVK Silver Donating Members 751 Member For: 18y 4m 9d Gender: Male Location: North West Hot Hell,VIC Posted 08/02/17 06:55 PM Share Posted 08/02/17 06:55 PM Fix your ignition key and barrel first before you start chasing your tail. Link to comment Share on other sites More sharing options...
4321 Bronze Donating Members 257 Member For: 10y 1m 1d Posted 09/02/17 08:08 AM Share Posted 09/02/17 08:08 AM I agree with JVK, you have to replace the column (not as big a job as it sounds, just change over the key & barrel without moving the sterring shaft) The ignition switch is caught between ignition'on' & start. Try turning the key back a bit Link to comment Share on other sites More sharing options...
Les M New Member 1 Member For: 7y 3m Gender: Male Location: Canberra Posted 11/02/17 04:15 AM Share Posted 11/02/17 04:15 AM (edited) I had the same problem was driving me mad. So last week a stupidly washed the motor and it went haywire every 50m the speedo would stop and the engine coughing and missing, figured I had got water on the coil packs. May as well put new plugs in if I am going to dry them, was going to go full on and change the speed sensor on the gearbox as well, as that seemed to be causing the speedo issue. Ford were out of stock so I went to a local auto trans shop to get one got talking with him about it he asked if the ute had been idling rough which it had for a while he then said to change the coil packs to fix the problem ? I did and now have no issues with the ute at all runs perfect and no more speedo dramas. May not work for everyone but did for me. I had the same 3 lights flash ABS Handbrake and Traction control Edited 11/02/17 04:16 AM by Les M 1 Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,310 Member For: 16y 17d Gender: Male Location: Melbourne Posted 11/02/17 04:24 AM Share Posted 11/02/17 04:24 AM Les. Good result for you, most definitely. Yours was clearly that way because you washed the motor without protecting the electrical parts first Link to comment Share on other sites More sharing options...
