  • New Member
  • Member For: 10y 13d
Posted
Hey  Im looking at some almost brand new FGX struts and leafs to put on my 09 FG T. Just wondering if people know if they fit?. Im more than happy to go back to standard height front and rear as mine is really low and front struts are worn out. And as I use it for work I need the back especially at standard height.
  • New Member
Posted
Here is where she sits now with no tools in. With tools approx 150 to 200kg the backs level with the front. Is this standard height as it seems low.
  • skids
  • Legacy Donating Member
  • Member For: 13y 8m 23d
  • Gender: Not Telling
Posted (edited)
hey man the car looks good given that one side of the car is up on the kerb. and it has 19's. edit: looks standard to my eyes.
Would go for an aftermarket brand at standard height.
standard height is the best in my opinion...being able to do an oil change in the driveway without having to jack the car up is awesome.
Edited by skidxr6t
  • New Member
Posted
Yeah in that photo it is on the curb so may be pushing it down a little.front springs look standard .when I first bought it had 50mm lowering blocks on the rear leafs. The front shocks are shagged so will need replacing and on gumtree I came across a full FGX xr6 standard suspension for $400. Was thinking for the money could do almost new standard setup. Which is about the price of new aftermarket struts and springs for the front alone. Only sticking point is getting them shipped Melb to Syd.
  • skids
Posted
whys it all shagged m8 have you been doing burnouts in it ay?
got any mods on it?
  • New Member
Posted
Just front shocks are worn  bounces round a bit. The previous owner had deleted the intake muffler and relocated the battery. Has pod filter straight off the turbo and blocked off the blow off valve. So makes heaps of noise. Also unsure if this is stock but off the turbo has a 3 inch pipe back to one muffler and the rest is just straight pipe. And certainly will turn the tyres to smoke instantly,you know just to test the LSD haha. But needs a centre bearing so got a quote from Hardy spicer for a uprated one that's 330 if I bring the driveshaft to them to change over the bearing,280 if I just buy it.
 Hoping to get the bigger injectors,xcal4 and tune for around 1500 in the future.
  • Member For: 10y 4m 1d
Posted
Just buy new. I've bought second hand before and they were shagged. They looked good but once fitted they showed they're true colours.
Sounds like yours already has a few mods. It's most certainly had a tune in the past. Otherwise it wouldn't run real well with those mods.
  • New Member
Posted
Yeah unsure if its tuned as previous owner reckoned he didnt. I might just put the stock intake back and battery in the right place as its all a little dodgy and see how she goes. Other interior mods were a F6 interior (seats ,door cards, console) with mk2 ICC. The ICC works ok for the bluetooth etc but have to set the dimming bright to see it through the day. If I have any probs with any of the mods luckily I have all the original parts.
Here is the second hand stuff I was looking at.
http://www.gumtree.com.au/s-ad/kinglake-west/brakes-suspension/ford-falcon/1128404270
Or find something aftermarket and just do the front springs and struts and do the rear shocks only and leave my leafs.
  • FREAKY
  • Member For: 16y 8m 26d
Posted (edited)
same sh*t as FG. ford had no money to upgrade anything from ba onwards for the utes haha
take your ute to CMS if your in sydney get them to check what dodgy sh*t previous guy did. re tune etc.
Edited by Ford Freak
  • New Member
Posted
Well I ended up putting the stock intake back on and moving the battery etc. Seems to run ok no real difference in power that I can notice. Was probably sucking hot air from the engine bay before anyways. Will run it like this for awhile and see how it goes.
