  • Legacy Donating Member
  • Member For: 16y 1m 24d
Posted
hey all, about to pull the trigger on the IMS diff kit and am a bit confused as to whether I should also order the extra front diff mount bushes? did anyone else buy this extra who fit this diff kit? the car had a bit of work done at pedders a few years ago replacing all sorts of bushes in the rear end so not sure if this bush also got changed.
cheers
  • less WHY; more WOT
  • Site Developer
  • Member For: 18y 5m 29d
Posted
While it's apart, you may as well replace the two side diff bushes as well. The rest only need to be replaced on a case-by-case basis, imho.
  • Moar Powar Babeh
  • Member For: 21y 16d
Posted
Change everything you cannot change with the diff cradle in situ.
Posted
it seems superpro discontinued the bush IMS sell, part #SPF3148AK and replaced it with #SPF3148PK. are there any differences?
  • Site Developer
Posted
seems like a question for superpro... :idunno:
  • Moar Powar Babeh
Posted
PK part number is the newer dual density Polylast bush. Personally I'd (and will be when my IMS hat goes in) go stock ford front. The IMS hat will stop the uneven side torque load that kills the lhf bush.
Posted
any chance you'd know the part number of the stock ford bush?
  • Dropping a turd
  • Member For: 18y 11m 12d
Posted
24 minutes ago, Ralph Wiggum said:
Nah no idea
Stock fronts and a set of these-
http://www.whiteline.com.au/product_detail4.php?part_number=W93240
Is what I'll be using.
Any reason you don't use polyurethane.  I don't have any noise in the territory since upgrading
