Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 18y 7m 5d Gender: Male Location: Perth Posted 11/08/16 01:49 AM Share Posted 11/08/16 01:49 AM Generally not suitable for turbos due to clearance issues with the rad/intercooler. Non of the off the shelf kits will give you enough hose for a behind the fog light mount. Link to comment Share on other sites More sharing options...
Ale Member 249 Member For: 12y 8m 3d Posted 11/08/16 01:51 AM Share Posted 11/08/16 01:51 AM Thanx heaps mate, clears it up. Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 18y 7m 5d Gender: Male Location: Perth Posted 11/08/16 01:58 AM Share Posted 11/08/16 01:58 AM Personally I buy the cooler and fittings and spec my own hose. I've done 3 of the Mega cools (inc my own car) and all up it'll run you 5 to 6 hundred by the time it's installed but I don't think you can go past it for the combo of size/quality/performance. Link to comment Share on other sites More sharing options...
Ale Member 249 Member For: 12y 8m 3d Posted 11/08/16 02:15 AM Share Posted 11/08/16 02:15 AM (edited) Definitely looks the heaviest duty: biggest, thickest core, plus the big Fan. Furious performance do a similar kit using Teflon braid and PWR core: http://www.furiousperformance.com.au/retail_catalogue/TCK-FURFALCON_item.html?ref_cat_id=Coolmaster-Trasnsmission $850 and thinner core compared to yours. Edited 11/08/16 02:15 AM by Ale Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 18y 7m 5d Gender: Male Location: Perth Posted 11/08/16 02:19 AM Share Posted 11/08/16 02:19 AM that's a good price considering braided hose and fittings etc included. If I was paying retail for parts I doubt I'd be able to get it any cheaper. Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 16y 6m 1d Gender: Male Location: Perth Posted 11/08/16 05:35 AM Share Posted 11/08/16 05:35 AM (edited) If your going to fit a cooler with fan, may as well fit one that is thicker for extra cooling, seeing it wont have natural air flow. Stock is 19mm, these are 32mm and come in 2 sizes. I use one as my engine oil cooler. Its similar to ralphs one. Fan draws air. You could always install it here. Edited 11/08/16 05:39 AM by arronm Link to comment Share on other sites More sharing options...
Ale Member 249 Member For: 12y 8m 3d Posted 11/08/16 05:54 AM Share Posted 11/08/16 05:54 AM Yeh, not sold that I need one with a fan for my application. Adds a bit of complexity with a relay and ensuring the fan is switched in relation to the oil temp. Link to comment Share on other sites More sharing options...
brendo169 Member 5 Member For: 11y 7m 26d Posted 14/08/16 10:11 AM Share Posted 14/08/16 10:11 AM Another option is the PWR replacement oil/coolant heat exchanger unit. It seems to be a really nice bit of kit and no mucking around with wiring or running oil lines etc. Link to comment Share on other sites More sharing options...
ROB83R Member 1,632 Member For: 7y 11m 9d Gender: Not Telling Location: Radioactive wasteland Posted 14/08/16 10:16 AM Share Posted 14/08/16 10:16 AM ^^^ also prone to failure. Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 16y 6m 1d Gender: Male Location: Perth Posted 14/08/16 10:19 AM Share Posted 14/08/16 10:19 AM Has some PWR failed??? Link to comment Share on other sites More sharing options...
