TheMont New Member 4 Member For: 8y 11m 14d Posted 13/07/16 09:14 AM Share Posted 13/07/16 09:14 AM G'day fellas, I've recently decided to try and get a bit more power out of my XR6 FG N/A, I know it's no turbo but I'm planning on keeping this car for awhile. Anyway I chucked on a Herrod cai, then an exforce catback followed by a pacemaker 4495 and an high flow cat, then finally an under drive pulley. I also bought new O2 sensors, changed the oil and oil filter, then today changed the fuel filter. My first problem is that from where both the cat connects with the cat back and headers there are leaks of like a water substance with white smoking coming from the exhaust on start but goes away once warm, I don't think this means anything so I just let the car warm up before I drive. The real problem is that when the car is in drive and I'm just rolling it like jolts/jerks/jumps forward and the same when I put in reverse. It doesn't happen all the time but does occur quite often, especially in the mornings stuck in traffic. Also occasionally when I go to accelerate there is a slight delay kinda of feel, I can't really explain it but it just sometimes waits a second then goes, but like I said this barely happens. My first thought was the fuel filter so I changed it today and still no change, could it be because I have yet to have it tuned? Is it running a bit lean and the tune will fix all this? Or is it something more serious? Please would love to hear your thoughts. Cheers Link to comment https://www.fordxr6turbo.com/forum/topic/92174-xr6-fg-na-jerkingjumping/ Share on other sites More sharing options...
skidxr6t skids Donating Members 2,754 Member For: 12y 5m 30d Gender: Not Telling Posted 13/07/16 09:42 AM Share Posted 13/07/16 09:42 AM you gota fit a turbo to it and get it tuned on e85 to fix your cars problems 1 Link to comment https://www.fordxr6turbo.com/forum/topic/92174-xr6-fg-na-jerkingjumping/#findComment-1600854 Share on other sites More sharing options...
BAXRTUTE Gold Donating Members 2,639 Member For: 9y 2m 9d Posted 13/07/16 09:56 AM Share Posted 13/07/16 09:56 AM 3582 lol Link to comment https://www.fordxr6turbo.com/forum/topic/92174-xr6-fg-na-jerkingjumping/#findComment-1600861 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 9m 4d Gender: Male Location: Perth Posted 13/07/16 10:50 AM Share Posted 13/07/16 10:50 AM Just roll with it 1 Link to comment https://www.fordxr6turbo.com/forum/topic/92174-xr6-fg-na-jerkingjumping/#findComment-1600863 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,575 Member For: 17y 2m 18d Gender: Male Location: Melbourne Posted 13/07/16 02:05 PM Share Posted 13/07/16 02:05 PM tailshaft centre bearing is shagged or diff bush is split/broken or diff bush bolt is broken (probably not the latter). Link to comment https://www.fordxr6turbo.com/forum/topic/92174-xr6-fg-na-jerkingjumping/#findComment-1600909 Share on other sites More sharing options...
TheMont New Member 4 Member For: 8y 11m 14d Posted 13/07/16 10:24 PM Author Share Posted 13/07/16 10:24 PM Yeh mate it does sound similar to the diff bush being split/broken as I does like wind back and jump, but could it be something else? Like it only happens when rolling in either drive or reverse, no other time. Thanks Link to comment https://www.fordxr6turbo.com/forum/topic/92174-xr6-fg-na-jerkingjumping/#findComment-1600918 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,575 Member For: 17y 2m 18d Gender: Male Location: Melbourne Posted 14/07/16 01:05 AM Share Posted 14/07/16 01:05 AM it could be multiple things... but those are the most likely. Link to comment https://www.fordxr6turbo.com/forum/topic/92174-xr6-fg-na-jerkingjumping/#findComment-1600936 Share on other sites More sharing options...
barnz Member 3,047 Member For: 11y 7m 7d Gender: Male Location: Brisbane Posted 14/07/16 03:08 AM Share Posted 14/07/16 03:08 AM How many k's and has the box been serviced. Different ZF but mine did similar things when a bit low on fluid. Would flare on cold shifts, surge a bit at light throttle when trying to cruise. Felt like it had a big cam when cold and put it in gear. Idle fine out of gear. Put maybe a touch over 100ml of oil in it and its been a sh*te load better. Still needs a service. Link to comment https://www.fordxr6turbo.com/forum/topic/92174-xr6-fg-na-jerkingjumping/#findComment-1600965 Share on other sites More sharing options...
TheMont New Member 4 Member For: 8y 11m 14d Posted 14/07/16 06:01 AM Author Share Posted 14/07/16 06:01 AM Yeh mate I was watching the revs today driving and it would hold at around 2 and a half, and then when braking it would seem like it was holding gear then dropping at the last second. Very uncomfortable ride Link to comment https://www.fordxr6turbo.com/forum/topic/92174-xr6-fg-na-jerkingjumping/#findComment-1601000 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 9m 4d Gender: Male Location: Perth Posted 14/07/16 10:34 PM Share Posted 14/07/16 10:34 PM On 13/07/2016 at 5:14 PM, TheMont said: G'day fellas, I've recently decided to try and get a bit more power out of my XR6 FG N/A, I know it's no turbo but I'm planning on keeping this car for awhile. Anyway I chucked on a Herrod cai, then an exforce catback followed by a pacemaker 4495 and an high flow cat, then finally an under drive pulley. I also bought new O2 sensors, changed the oil and oil filter, then today changed the fuel filter. My first problem is that from where both the cat connects with the cat back and headers there are leaks of like a water substance with white smoking coming from the exhaust on start but goes away once warm, I don't think this means anything so I just let the car warm up before I drive. The real problem is that when the car is in drive and I'm just rolling it like jolts/jerks/jumps forward and the same when I put in reverse. It doesn't happen all the time but does occur quite often, especially in the mornings stuck in traffic. Also occasionally when I go to accelerate there is a slight delay kinda of feel, I can't really explain it but it just sometimes waits a second then goes, but like I said this barely happens. My first thought was the fuel filter so I changed it today and still no change, could it be because I have yet to have it tuned? Is it running a bit lean and the tune will fix all this? Or is it something more serious? Please would love to hear your thoughts. Cheers 7 Link to comment https://www.fordxr6turbo.com/forum/topic/92174-xr6-fg-na-jerkingjumping/#findComment-1601170 Share on other sites More sharing options...
