zlaya79 Member 10 Member For: 11y 1m 22d Posted 01/07/16 01:23 AM Author Share Posted 01/07/16 01:23 AM On 29/06/2016 at 11:15 AM, Ralph Wiggum said: Sorry cannot recomend anyone Sydney mate. Same model and config will work. You'll still need to work throught the process listed above though. If I was you I would sitll pursue the Repair option if possible. Also have a look here if you do go down the replacement list- https://www.bulletperformanceracing.com.au/BA PPC Data Base.html It should help you determine if a replacement will be suitbale. All good mate, thought I'd check anyway. I'm getting the car back into my garage, will take out the unit and see who can repair, if at all possible. Then will go down the path of "patching" another one, if need be. Yep, came across that link a while ago and it blew my mind with the number of different part numbers for what is essentially the same car (at least the ones for BA/BF). What were they thinking?? Thanks again, mate, much apprecaited! On 29/06/2016 at 11:24 AM, k31th said: fair dinkum... didn't realise there were so many different PCM/ECU codes... no wonder why people have issues trying to source/use them Yep, total effin instanity, right ?!?! Link to comment https://www.fordxr6turbo.com/forum/topic/92103-ecu-for-a-ba-xr6-turbo/page/3/#findComment-1598461 Share on other sites More sharing options...
rollex Member 683 Member For: 10y 11m Gender: Male Location: Australia Posted 19/08/16 12:25 AM Share Posted 19/08/16 12:25 AM (edited) Contact Grant at custom tuning in Vic, pretty sure he can do this for you if you mail your ECU to him. It is a bit of a *beep* to get it out, you can unscrew the tamper proof screws with vice grips if you spend 45 mins on it. I hacksawed some slits into them so they can be easily removed afterwards as well. http://www.customtuning.com.au/ custom-tuning@hotmail.com Something else to consider, how different is a BF ecu? Could you flash a BA program into it? I'm pretty sure you can do the reverse. The PCMs might have different codes but I'm pretty sure physically they are the same, they just have different programs (strategys) on them which can surely be flashed between the differnet models without issue. HPTuners for example will let you flash a different strategy into your PCM, you can also fairly easily hack the binary to change the VIN afterwards. Edited 19/08/16 12:28 AM by rollex Link to comment https://www.fordxr6turbo.com/forum/topic/92103-ecu-for-a-ba-xr6-turbo/page/3/#findComment-1608171 Share on other sites More sharing options...
Grudge New Member 1 Member For: 8y 3m 4d Posted 22/02/17 07:58 PM Share Posted 22/02/17 07:58 PM On 24/06/2016 at 10:09 AM, zlaya79 said: Hi all, I've got a BA XR6 turbo and according to my mechanic, my ECU seems to have had it. Apparently, a common thing with these units. The particular part number in question is discontinued with Ford and second handers are as rare as hens teeth it seems. This might be a long shot, but just wondering if anyone here has any connections or knows someone who knows someone (We called just about everyone in the country who does spares). ECU code: ABU-214 / 3R23- 2A650-HE Much appreciated! Try mr ford in Sydney bro Link to comment https://www.fordxr6turbo.com/forum/topic/92103-ecu-for-a-ba-xr6-turbo/page/3/#findComment-1632580 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,487 Member For: 17y 28d Gender: Male Location: Melbourne Posted 22/02/17 10:03 PM Share Posted 22/02/17 10:03 PM but you might be a little late on that one haha he's probably already got an ECU as he hasn't even visited this thread since 11th July 2016. Link to comment https://www.fordxr6turbo.com/forum/topic/92103-ecu-for-a-ba-xr6-turbo/page/3/#findComment-1632582 Share on other sites More sharing options...
rollex Member 683 Member For: 10y 11m Gender: Male Location: Australia Posted 22/02/17 10:37 PM Share Posted 22/02/17 10:37 PM Wonder if someone just flashed another ECU with the same file. Surely the later model ECUs would work as well. Did they really change that much ECU wise over the years in the BA ? Link to comment https://www.fordxr6turbo.com/forum/topic/92103-ecu-for-a-ba-xr6-turbo/page/3/#findComment-1632585 Share on other sites More sharing options...
JVK Silver Donating Members 751 Member For: 19y 4m 20d Gender: Male Location: North West Hot Hell,VIC Posted 26/02/17 07:59 PM Share Posted 26/02/17 07:59 PM There must be some difference. I am pretty sure the bf will flash alot quicker than the ba ones iirc. Link to comment https://www.fordxr6turbo.com/forum/topic/92103-ecu-for-a-ba-xr6-turbo/page/3/#findComment-1632926 Share on other sites More sharing options...
