Fg Mk2 Headlights Fitting On Mk1
rabbzh
  • Member For: 8y 4m 7d
Hi iv got a mk1 xr6t and im wanting to put the mk2 front end on does anyone no if headlights and bumper will bolt straight on and if any wiring is involved with headlight
Sent from my SM-G920I using Tapatalk
  • Member For: 16y 11m 26d
Most of it bolts straight on.
Headlight wiring for low beam is different. You will need to do some wiring changes as Mk1 uses a H4 which has a dual element globe with low and high. Mk2 only has single element globe
  • 2 weeks later...
  • 7 months later...
  • Member For: 7y 8m 2d
Hi mate  I WHANT to do the same  eny devise
  • 1 year later...
  • Member For: 6y 19d
Hi there, I had a little accident and I needed 2 new FG XR6 MK1 headlights.
I wanted to upgrade this to MK2 and reading this post I should do a proper wiring for them.
Someone has done this job already? Any scheme of the wiring? Any suggestion? Any guide?
Thanks :D
  • less WHY; more WOT
  • Site Developer
  • Member For: 16y 17d
the only different shape (on the outside) is the low beam globe mount at the back (unless you mean XR vs FPV, as XR has the twin curves at the bottom, FPV is flat).
The wiring (for only the low beam) is probably just a matter of getting or making a connector(s) for the pins of the new globe type and removing the old connector and then joining just the pos/neg of the wiring as you don't need the relay portion anymore.
  • FREAKY
  • Member For: 14y 4m 2d
I dont think the bumpers are different
should be straight swap but there is some wiring needed or a resister or some mumbo jumbo wizz bang thingo needed.
