boost69 Donating Members 737 Member For: 20y 28d Posted 16/11/15 09:11 PM Share Posted 16/11/15 09:11 PM Guys,Sometimes when I give it the boot and then back off suddenly I can feel diff backlash.Is this normal?The car has been jacked up and there is a bit of play when you turn the tail shaft.As in there is a bit of play before the diff engages and turns the wheels.Car is still under warranty, not sure what Ford would do to fix the problem short of changing the diff... 1 Link to comment https://www.fordxr6turbo.com/forum/topic/91396-driveline-backlash/ Share on other sites More sharing options...
f-wolf Member 897 Member For: 18y 1m 22d Gender: Male Location: ACT Posted 16/11/15 09:29 PM Share Posted 16/11/15 09:29 PM It's Normal ! You will get used to it. I / we got used to it ! Link to comment https://www.fordxr6turbo.com/forum/topic/91396-driveline-backlash/#findComment-1570402 Share on other sites More sharing options...
boost69 Donating Members 737 Member For: 20y 28d Posted 16/11/15 09:38 PM Author Share Posted 16/11/15 09:38 PM Lol...it's funny how we accept these things aye...is it because the price and performance of these cars makes up for these little gremlins you have to deal with? 1 Link to comment https://www.fordxr6turbo.com/forum/topic/91396-driveline-backlash/#findComment-1570406 Share on other sites More sharing options...
barnz Member 3,047 Member For: 11y 6m 27d Gender: Male Location: Brisbane Posted 16/11/15 09:46 PM Share Posted 16/11/15 09:46 PM Lol theres normal and theres f*cked. Was having sus at mine last night, roll on 3rd at 60k's squeeze gently to WOT throttle and no matter how gently I lift at around 3000rpm which I think is about 80k, massive clunk. I bet im going to find a split bush or maybe even a broken bolt it sounds pretty violent. A little in a ZF equipped car is normal... 1 Link to comment https://www.fordxr6turbo.com/forum/topic/91396-driveline-backlash/#findComment-1570411 Share on other sites More sharing options...
Rab WOT? Moderating Team 10,981 Member For: 12y 3m 21d Gender: Male Location: Frankston, 3199 Posted 16/11/15 09:55 PM Share Posted 16/11/15 09:55 PM (edited) I reckon I lucked out and got the wrong end of the "within tolerances" of each part that causes the backlash/clunk.Even get it at times while sitting on 100km/h on the freeway on cruise control when it comes on/goes off the throttle :SBeen checked - all is within specIt can be pretty damn violent when driving spiritedly - only solution is to change the driving style to not come off the gas too quickly Edited 16/11/15 09:56 PM by Rab 1 Link to comment https://www.fordxr6turbo.com/forum/topic/91396-driveline-backlash/#findComment-1570414 Share on other sites More sharing options...
PTR_NITRO_FG Donating Members 3,214 Member For: 12y 21d Gender: Male Location: NOR Perth Posted 16/11/15 11:01 PM Share Posted 16/11/15 11:01 PM Impossible for me....that's how I get max dose! Lol 2 Link to comment https://www.fordxr6turbo.com/forum/topic/91396-driveline-backlash/#findComment-1570427 Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 6m 22d Gender: Male Location: Probably above atmospheric pressure Posted 17/11/15 04:57 AM Share Posted 17/11/15 04:57 AM (edited) It can be pretty damn violent when driving spiritedly - only solution is to change the driving style to not come off the gas too quicklyMy experience too.Give it heaps and back off too fast at the wrong time...BANGI'm amazed I haven't snapped something, I've done it hundreds of times.Got tailshaft coupling and centre bearing/uni joint replaced recently which really helped...for about two weeks/1000km. Edited 17/11/15 04:58 AM by -Stever- 1 Link to comment https://www.fordxr6turbo.com/forum/topic/91396-driveline-backlash/#findComment-1570555 Share on other sites More sharing options...
velocityxr6t Member 122 Member For: 16y 7m 3d Gender: Male Posted 18/11/15 06:43 AM Share Posted 18/11/15 06:43 AM So are you guy's getting the knock even on light acceleration? Every time I take of in the ute from a standstill, even at grandma pace, mine is knocking. Link to comment https://www.fordxr6turbo.com/forum/topic/91396-driveline-backlash/#findComment-1570728 Share on other sites More sharing options...
Rab WOT? Moderating Team 10,981 Member For: 12y 3m 21d Gender: Male Location: Frankston, 3199 Posted 18/11/15 07:48 AM Share Posted 18/11/15 07:48 AM Nah - not on taking off - it's when you load up the rear then release.Accelerating then taking the foot off the pedal 1 Link to comment https://www.fordxr6turbo.com/forum/topic/91396-driveline-backlash/#findComment-1570745 Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 6m 22d Gender: Male Location: Probably above atmospheric pressure Posted 18/11/15 01:50 PM Share Posted 18/11/15 01:50 PM I left a marble in your tray, April Fools! Link to comment https://www.fordxr6turbo.com/forum/topic/91396-driveline-backlash/#findComment-1570787 Share on other sites More sharing options...
