September 11, 201511 yr #1 Looking at getting Brembo's for the G6ET.As I've recently upgraded to DBA,T3 rotors (standard diameter), will I have to change to larger rotors, or can I use the DBA's?
September 11, 201511 yr #4 Author You're right Bizkets the stock diameter is 322mm.My point is, for street use only, the Brembo's on standard diameter rotors will still be much better than the standard calipers. Just interested whether there are caliper brackets available, that allow Brembo's to be fitted to the 322mm rotors.
September 11, 201511 yr #9 For your next upgrade, buy a bigger intercooler then restrict the airflow in the bigger pipes because you won't need that much power for street use.
September 11, 201511 yr #10 I was not sarcastic. You'll damage the calipers and pistons if you try to use them on a surface that is too small.
